805 and 875 overheating
NewHTguy
NewHTguy Posts: 584
edited June 2008 in Electronics
I've been considering upgrading from my Onkyo 605 to either the 805 or 875. Some of the reviews on Amazon claim that these AVRs get too hot and, in a few instances, have actually started to smoke! I'm wondering how often this has happened and whether this was due to keeping the AVRs in an unventilated cabinet. Anyone have the same bad experience? Are these isolated incidents?
MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s
Post edited by NewHTguy on
    billbillw Posts: 8,108
    edited May 2008
    All of the Onkyos make a lot of heat. They will not work in an enclosed cabinet. Some people fail to follow the guidelines for proper ventilation and have problems. If you can give the 805/875 room to breath, you shouldn't have any problems.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2008
    The 705, 805, 875, etc. have dual thermal-controlled cooling fans beneath the heatsinks which should keep things quite cool. In fact, my 705 is in an open area and I've never heard them come on. If you're putting ANY receiver in an enclosed cabinet, you need to work out ventilation.
    I think the 805 overheating problems are fairly isolated. The vast majority are working fine.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • demaples
    demaples Posts: 266
    edited May 2008
    My 805 gets warm but has never been a problem. I bought a pair of fans with a thermostatic switch off of ebay for about $40 for my Rotel but it never even gets warm so I placed them on the 805 for back up. They come on occassionally since it is partially enclosed on a shelf.
    Hitachi 50" Plasma full HD 1080--Onkyo 805 AVR
    Rotel RMB-1077 amp--Polk LSic center
    Polk LSi25 fronts--Polk LSi 15 rears
    Genesis G-2800 sides--Polk PSW 650 sub
    APC H15 power conditioner--Netgear digital media player
    Napster external hardrive--Linksys Wireless G router
    Samsung DVD--Blue Jeans wires
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2008
    my 805 gets pretty dang hot. i added a cooling for for a pc to the top of mine and it's helped keep her cool. many have done this to their 805.
    p.s. my 805 is out in the complete wide open.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • sagasa
    sagasa Posts: 127
    edited May 2008
    I use small clip on oscillating fan, I clip it on the back and turn it on when needed.
    It works fine the 805 stays cool..
    Front: Tekton Pendragon
    Center: Tekton Pendragon
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
  • NewHTguy
    NewHTguy Posts: 584
    edited May 2008
    Thanks for your feedback. Can't help but get a little worried when electronics start smoking... Seems that the 875 runs hotter than the 805. Can anyone out there comment on the 875?
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2008
    My Onkyo TX-SR702 gets very warm at times, even with nothing on top of the unit. In fact it sits in the open on top of a small table and still gets very hot.
    I would recommend having plenty of space around the unit and making sure that it is well ventillated.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited May 2008
    NewHTguy wrote: »
    The 875 probably does run warmer, due to the REON chip. I have the PR-SC885, which is a pre-amp, no amps inside. It ran very warm, especially over the REON chip, which will burn you if you touch it! It also runs very warm on the opposite side over some large heatsinks with two transistors attached. I have attached a picture of the 9.8, which is identical to my unit.
    What I did was put a heatsink on the REON chip, and I have a small 12v 60mm fan (running off 6v, so it's silent), directly behind the heatsinks pulling hot air out of my closed cabinet. It's cool as can be now.
  • JDOGG
    JDOGG Posts: 433
    edited May 2008
    If anyone feels theirs is running too warm and is looking for ideas to help cool it, here is something to look into. http://coolerguys.com/comcool.html
    If mine runs too hot, I am gonna pick that up.
    Panasonic VIERA 46" 1080p plasma
    Onkyo TX-SR805
    Klipsch RF-7(bi-amped)
    Klipsch RF-25
    Xbox 360 with HD DVD
    Playstation 3
    Cobalt Cable
  • LushMojo
    LushMojo Posts: 29
    edited May 2008
    Ours got very hot. Sent it back and got a Denon 3808. Sounds much better and the video processing looks better than the Reon (to my eye, anyway).
  • NewHTguy
    NewHTguy Posts: 584
    edited May 2008
    WilliamM2, That's cool but I think doing something like that is out of my league. Also, alterations of that sort may invalidate the warranty. Is that right?
    Lush, Does the Denon 3808 upscale the signal from, say, a cable box over hdmi?
  • WilliamM2
    edited May 2008
    NewHTguy wrote: »
    The heatsink is just a self adhesive type from my collection of computer parts, it can be removed if need be. The fan is not mounted to the 885, but to the back of my equipment cabinet, no alteration there.
  • JDOGG
    JDOGG Posts: 433
    edited May 2008
    JDOGG wrote: »
    Well the back right corner gets really hot, so I am gonna grab one of those up and hopefully that will cool it down a bit.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • jon s
    jon s Posts: 905
    edited May 2008
    the onkyo 875/905s do get extremely hot... and it is definitely from the reon processor. if you select pure audio mode which disables the video circuitry, the onkyo runs cool. i have a denon 3930ci with the realta video processor (an upgraded reon) and it really cooks too.
  • NewHTguy
    NewHTguy Posts: 584
    edited May 2008
    Thanks Jon. That's useful info.
    Btw, how is the video upscaling with the 3930?
  • avguytx
    avguytx Posts: 1,628
    edited May 2008
    I sell/own Onkyo/Integra stuff and anymore these days, it's the video processing circuitry that gets the most warm anymore....even at idle. With ANY receiver this can happen, too. I use fans on my stuff that's in an enclosed entertainment center from this company...www.coolcomponents.com. They have a huge variety of cooling options and we have a lot of the custom A/V installers in the DFW area (plus the rest of the territory we cover) that uses them. Very economical. Just my $.02 and YYMV. :D
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • NewHTguy
    NewHTguy Posts: 584
    edited May 2008
    If I find a good deal on an 875 or 905, I'll definitely add a fan.
  • kuntasensei
    edited May 2008
    I say if you're not doing much in the way of scaling, screw the 805/875. Grab a 705 instead and look for a cheap external amp if you feel you need more power. As a pre-pro, the two are basically the same.
    Equipment list:
    Emotiva XPA-3 amp
  • NewHTguy
    NewHTguy Posts: 584
    edited May 2008
    kuntasensei, that may be a way to go. Basically I would be paying for pre-outs... Is the 705's audio better than the 605? I must admit that I would like something that helped with the crappy sd cable signal.
  • kuntasensei
    edited May 2008
    No pre-outs on the 605. Plus, the 605 only has Audyssey 2EQ whereas the 705 has MultEQ XT (so the 605 doesn't EQ your sub at all). The 605 also doesn't have the DSP power to apply 5.1 to 7.1 processing on lossless 5.1 tracks if that matters to you.
    As far as 705 vs. 805 on the audio side, the decoding is the same. The 805 has better DACs, but the difference is essentially inaudible.
    Equipment list:
    Emotiva XPA-3 amp
  • xandra
    xandra Posts: 291
    edited May 2008
    ABOUT HEAT: I own a 705 which is in a cabinet with 4" above, 1 1/2" on sides The cab's back is open and I leave the front door open while running. In this enviorment the thing remains VERY cool. So I wouldn't regard this model as hot.
    My sense from asst'd formuns is that the 805 (which doesn't have the reon but does have 30 watts more amplification) runs hotter. And I assume the 875 hotter still.
    As to Onk 705 vs 805
    The 805 has some minor but fairly useful upgrades to the 705 (in addition to power) Including: burr-brown DACs, one extra AV input (vital for those like me who've Maxed out available inputs), a flip down front (pretty useful dustguard), an extra Zone. The 805 has a great speaker terminal layout, and a 7 band equalizer, 12 pre-outs (vs 10). And, According to an Onk techie the amplification (or some aspect affecting sonic quality other than the DACs) is quite different between the models. (note THD diff .05 vs .08)
    But oddly the thing that appeals to me the most is the front panel "Audio Select" button which allows you to toggle thru available inputs for the selected device. for example you can hook up a device to both optical dig and analog and in one touch switch between them depending on what you're listening to... (you can achieve same with 705 -- but only within submenus)
    Lastly the 30 watts of additional power can make the difference of only needing to Amp fronts vs amping all channels. Admittedly, none of this is major, but now that sales are on for 805.. it seems worthy of consideration.
    sorry for the length... have been pondering this myself alot lately.
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • NewHTguy
    NewHTguy Posts: 584
    edited June 2008
    Xandra, you make some good points. And, the key is that the price differential between a new 705 and new 805 is only about $100. I'm not too worried about the 806's heat. However, I do worry about the 875. I think a fan is a must when you're not using the pure audio mode.
  • xandra
    xandra Posts: 291
    edited June 2008
    Yes, that's the point. Back when difference was about $300, it was harder to justify going with the 805. Don't get me wrong - I have the 705 and still think it's an amazing receiver for the price - but if I were choosing right now, I'd go with the 805. And yes, the heat with the 875 is big-league intimidating.
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
