D-Sonic 3 channel amp (Magnum 750-3)
pearsall001
pearsall001 Posts: 5,384
edited May 2008 in Electronics
Since I'm already set with my Krell KAV 250a (250w) two channel amp, I want to round out my system with a 3 channel amp & to keep the power about the same, the Magnum 750-3 is 250x3. I've read good things about the D-Sonic amps & I know a few here already have them & are very pleased with them.
What intrigues me about the D-Sonic amps is their small footprint & hi-power. The ICEpower modules that they use are very highly regarded in a number of areas, hi-power, no heat, reliability & the most important of all is their sound quality which is top notch.
I thought about a matching Krell KAVa/3 (3 channel amp) but it's just too darn big. Any other 3 channel amp suggestions you have for me are welcome.
http://www.d-sonic.net/
Post edited by pearsall001 on
  • engtaz
    engtaz Posts: 7,675
    edited May 2008
    Wouldn't a 3 channel Adcom go better with the Krell? Just asking.
    engtaz
    engtaz
  • pearsall001
    edited May 2008
    engtaz wrote: »
    engtaz
    That I really couldn't tell you. But I would think that in HT mode you would be hard pressed to hear any differences in sound using amps from different manuf. But for two channel listening the Krell would be the only workhorse playing. Maybe others could shed some light on the matter.
  • tryrrthg
    tryrrthg Posts: 1,896
    edited May 2008
    It doesn't have 10,000 watts :rolleyes: but it will sound damn good.
    http://cls.audiogon.com/cgi-bin/cls.pl?ampsmult&1213567524
  • Early B.
    Early B. Posts: 7,900
    edited May 2008
    Consider a 5-channel amp. The prices are similar between a 3 & 5 channel amps. Plus, you'll have more flexibility with a 5-channel amp.
    "God grooves with tubes."
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    There won't be much difference between most of the icepower based amps, especially ones using the smps power supply. The modules come premade from b&o, the only thing the company has that they can change is case, input wiring, and some do some mods. That said
    Early B. wrote: »
    If it was me I would look at a NHT Power5 if it wasn't to large. They pop up every week or so on Agon/Ebay for $1200, sometimes brand new. They use the same 250wpc modules as the D-Sonic, but it is a 5ch for less then the 3ch. The D-Sonic should be a phenomenal amp though, and run stone cold, at least from my experience with various icepower amps.
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2008
    Wow that NHT looks cool!
  • pearsall001
    edited May 2008
    Early B. wrote: »
    I hear ya Early, the only down side to that would mean that I'd have to give up my Krell!! :eek: I'm not ready for that just yet.
    Plus by going with a 3 channel amp, I have the option to play around with other two channel amps if the mood strikes me. Don't forget my dream amp is a Mac MC402. If I went with a 5 channel amp, then pulled the trigger on the Mac, then I'd be in a pickle. What to do??
  • Early B.
    edited May 2008
    I don't understand why you'd have to give up your Krell. Keep it and use only three channels of the 5-channel amp. Or you could bi-amp your fronts. Or you could power a couple of subs for stereo bass from the extra channels.
  • pearsall001
    edited May 2008
    Early B. wrote: »
    Space is a concern. Those 5/7 channel amps are usually pretty big & heavy. There's not much room left on my rack & putting another amp on the floor might be an option but a last resort. I already have my Krell on an amp stand on the floor between my mairs.
  • SlowcarIX
    SlowcarIX Posts: 887
    edited May 2008
    i got the d-sonic 2500-7, its no taller than a green tea jug
    also this thing is built like it tank, the modules are all braced. this thing will survive falling out of a speeding truck :D
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • pearsall001
    edited May 2008
    What's your thoughts on the sound quality? What did the new D-Sonic 2500-7 amp replace & did you notice any difference in performance?
  • SlowcarIX
    edited May 2008
    i went from the d-sonic M500S to the M2500-7
    hmm...sq, i would say they are neutral and effortless. Especially now with the DTS-HD MA soundtracks - they keep up with what ever i play thru them with gusto!
    regarding remaining cool, they do generate a bit of heat but not too much - my av processor gets hotter than this amp after i watch a movie at ear splitting levels.
    my 7.(1x4) HT setup
    Buttkicker
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2008
    I run the D-Sonic Magnum 1000S on my Rti12s, awesome amp, stays cool when left on 24/7. As you noted, small foot print but powerful. I would and will probably buy another one as slowcar has.
