Center Channel Stand height - help!
Hi all,
My center is currently sitting on 17" speaker stands in front of the TV stand, but it's blocking the remote sensors on some components on the stand.
I am planning to move to 13" stand:
http://www.tv-stands-shop.com/vti-dfc-df-series-center-channel-speaker-stand-p-155.html
or
http://www.tv-stands-shop.com/vti-vspc-vspc-series-center-speaker-stand-p-161.html
Is 13" too low (around knee level when sitting on the couch)?
What do you use for your center channel support? I currently can't install much above my plasma.
or
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
B&W CDM1-SE fronts
B&W CDM-CNT center
Post edited by ViperZ on
I currently use a 17" Plateau ST-CC. What is the plasma sitting on? Any way to move gear around?Michael
NORTH of 60° -
Have you tried a phantom center yet?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I don't want Phantom center, I want my real CS400
It's blocking my OTA tuner, as you can see in the picture.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Move your mains up the carpet and give it a try, it may work better than your CS400. It's free to try.
If you're dead set on having a center, place it 13" off the ground(use phone books, etc..) and see how it sounds to you."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Distance from center to the couch is only about 5', so no go on moving mains.
I'll try the phone books
B&W CDM1-SE fronts
B&W CDM-CNT center
I built my own stand for my CSI A6, to soit above my 50"plasma. It just out of MDF and spray painted black. It anin't perfect but it'll do untill my HT room is finished er (started).
I can post picks if you like but it 's not perfect..... -
dfranks - love to see how this looks - as I'll likely have to do the same...LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
Will do it by the weekend.
