PA + Polk Model 10's?
Would this work? I am trying to combine my dads old soundsystem to a friend's PA. His PA is 600W, but I am not sure about any other specifics.
The soundsystem I am working with is a Halfer DH-101 Preamp to a Halfer DH-200 amp and then to two old Polk Model 10 speakers.
Post edited by greeeenmachine on
  • jcaut
    jcaut Posts: 1,849
    edited May 2008
    Hi and welcome to the forum.
    I'm not really sure that I understand what you're wanting to do. If you're asking if the 10's would make good PA speakers then the answer is really no, they don't. There are a few exceptions, but home hifi equipment generally doesn't do well for PA, and pro sound PA equipment generally doesn't work well in a home hifi environment. Sure they can be connected, and I have seen several low-budget DJ setups where a guy will use some fairly high sensitivity "hifi" speakers and get away with it for a small venue (even been guilty of doing that myself) but it's not a good idea. You'd be VERY likely to damage the Mon 10's doing that.
    I apologize if that's not what you were asking. Give me more details and I'll try again.
    Jason
  • honda cber
    honda cber Posts: 267
    edited May 2008
    you WILL roast the tweeters. know that.
    a
    gear list:
    1 down, 4 up....
