Now how do you "Find all threads by..."
treitz3
treitz3 Posts: 20,041
edited May 2008 in Forum Testing Area
Tried to look up a thread started by Polkie "X" and had to end up going through 8 pages of the Buy/Sale area to find the daggum thread.
Also, the "chat" area with friends has some wording missing. The only way I found it was to click onto some arrow that was also half missing.
Running Firefox, is this why?
Post edited by treitz3 on
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited May 2008
    Click on "show all statistics" in the user profile.
  • tcrossma
    tcrossma Posts: 1,301
    edited May 2008
    You can either click on the person's name and select 'Find more posts by', or if you want to find only those threads started by a user click Search=>Advanced Search, type in the user's name, and select 'Find posts started by'.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    edited May 2008
    You both are correct. Tcrossma, you are correct but only in the test area as far as I can see. ZombieBoy, you are correct for the rest of the forum where it goes into the new settings.
    Thank you both.
  • tcrossma
    edited May 2008
    Maybe it is something with your browser then, not sure. When I use either the Advanced Search or the 'Find more posts by' methods, I get all posts across all forums, sorted by date descending.
    edited May 2008
    No, you were correct with both of the ways you described. Let me clarify. The first way you told me how to do it, only works in this [test area] forum....at least for me, that's how it works. Using the advanced search and then selecting "find all posts by" works like a charm every time. I was able to look up what I was trying to find earlier in a matter of seconds.
