Is this a good circular saw?
Early B.
Early B. Posts: 7,900
edited May 2008 in The Clubhouse
I was cruisin' Sears today and ran across this circular saw:
http://www.sears.com/shc/s/p_10153_12605_00925817000P
The regular price is $139.99 and it was NIB @ 50% off plus another 10% off that price. I'll rarely use it, but I'm a sucker for a "good deal." It will replace a cheap circular saw I bought 16 years ago.
I don't know much about power tools. Just wondering -- is this purchase a good deal? If not, I can always return it.
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • exalted512
    exalted512 Posts: 10,735
    edited May 2008
    So you got it for $63 + tax? Yea...very good deal.
    -Cody
  • obieone
    obieone Posts: 5,077
    edited May 2008
    I'm not a carpenter, but looks like a good deal. The only suggestion I've got, is to go to the Lowes/HD sites, and find comparable specs from the other brands like Dewalt, Makita etc. and check the price range.
    Don't really see how you can go wrong for that price, especially if you don't use that much.
  • hoosier21
    hoosier21 Posts: 4,418
    edited May 2008
    Not sure if they are still on sale or even in stock. but Home Depot had a Makita for 25.00 on clearance, I got it and it works just fine. The model that replaced it was 35 or 39.00.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited May 2008
    I think that is a very good deal on a 15 amp circular saw. Would never find a 15 amp up here that cheap.
    Sears stuff generally has good warrantees and good service as well.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Rivrrat
    Rivrrat Posts: 2,101
    edited May 2008
    Yeah, it was a good deal. I have an old Craftsman Commercial that's probably 30 yrs old now, and it's still going strong....Even after it accidentally went swimming in our pool a couple of years ago.
    I'd like a nicer one, but I can't justify the cost over what I already have.
    My equipment sig felt inadequate and deleted itself.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    A good blade is 90% of having good cuts. The frame is a nice cast frame on your unit. Looks nice. Don't cut yourself!
    Ben
    Ben
  • dfranks
    dfranks Posts: 207
    edited May 2008
    Anything made by craftsman is top notch and Yes I have that saw and it is great and Yes I am a carpenter.
    It's good enough for home use that's all
