Any power users of PowerPoint?
Early B.
Early B. Posts: 7,900
edited May 2008 in The Clubhouse
If anyone on this board knows PowerPoint real well, please PM me. I have a couple of questions. I know PPT can do what I want it to do, but I don't know how to do it.
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • Early B.
    edited May 2008
    Thanks for the link, haimoc.
    I'm actually trying to determine how to get photos to fade in and out on the same slide, and also to use this technique to create a montage. So I'd want to have something like 20 photos flowing in and out while I'm presenting, without having to press a button for each photo to come on screen.
  • Ricardo
    Ricardo Posts: 10,634
    edited May 2008
    On the menu:
    Slide show, Custom Animation.
    On the window at the right, Select Add Effect (Entrance, Exit); you can then define how to start the effect, and one of the options is "After Previous", for which you can determine the amount of seconds. You'll have to do the entrance/exit sequence for all the pictures.
    Have fun.
    SOPA
  • devani
    devani Posts: 1,497
    edited May 2008
    if you have access to adobe photoshop, you can make one file containing those pictures....
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • Early B.
    edited May 2008
    THANKS!!
    I'll try it later today.
