Any power users of PowerPoint?
Early B.
If anyone on this board knows PowerPoint real well, please PM me. I have a couple of questions. I know PPT can do what I want it to do, but I don't know how to do it.
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Thanks for the link, haimoc.
I'm actually trying to determine how to get photos to fade in and out on the same slide, and also to use this technique to create a montage. So I'd want to have something like 20 photos flowing in and out while I'm presenting, without having to press a button for each photo to come on screen.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
On the menu:
Slide show, Custom Animation.
On the window at the right, Select Add Effect (Entrance, Exit); you can then define how to start the effect, and one of the options is "After Previous", for which you can determine the amount of seconds. You'll have to do the entrance/exit sequence for all the pictures.
Have fun._________________________________________________
if you have access to adobe photoshop, you can make one file containing those pictures....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
THANKS!!
I'll try it later today.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
