Getting a new nome built and need help!
pcgorilla
I am getting a new home and will be having the builder wire it for 6.1 sound. Pretty nice. I will have 2 FXi50's in the rear with probably an R20 for rear center.
As for the front, I am stuck. I want to stay with polk. For my center I will have a CSi30 as a center and PWS 450 Sub. My TV is a Mits 65411.
My delima is, for the front speakers, I would like them small. I LOVE the flat look of the R7200/7600. I's pay $150.00 for each speaker, give or take a few $. I want to stay with an all polk system.
Are the fronts for the R7200's available by themselves ANYWHERE? The Rti28's are a bit bigger than I'd like in the front, but I just might bite if I find no alternative.
As for mounting, I was thinking of ceiling wired, with a bit of a drop/bracket, like a Ceiling fan drop, then hanging them off there.
I am attaching a photo of the model home. I'd love advice. By the way, in the model, they have the two ceiling speakers, just for showing.
Post edited by pcgorilla on
forgot photo.
I'd go in ceilings. A big (or small) speaker hanging down from the ceiling looks tacky. I know, I tried it. I'm not quite sure how you're going to get that TV to fit next to the fireplace. You may want to rethink the tv placement.
the TV spot is in a Niche, it is cut for big screens. I don't know how I should place the speakers though. The dimentions are perfect for my TV, so it cannot go anywhere else.. I's like small satellites to put for L/R
Then I'd go with in ceiling like they've got it. KEF has an inceiling that drops down out of the ceiling if you want hi-tech. Otherwise, make sure you get aimable tweets at a minimum. Otherwise, you're highs will sound awful. I think all the new polks have aimable tweets. I prefer the rectangular in walls over the rounds for sound quality.
I just spoke to Polk Customer Service. They said I can buy the 7600 or 7200 speakers individually. I think I'll take the 7600's for the front and mount them on the wall.
I'm in the process of upgrading to the LSi series and have 2 of the RM7600 sats and the RM7600 center that I would be willing to sell. I was thinking that instead of a R20 in the surround back position, you could use the built-in bracket on the 7600 center and wall mount it. I would do all 3 for $450.
sweet. email me: mike@pcgorilla.com
What does Polk want for the 7600's? They might be a good option for my back surrounds. -
they want 249 for the 7600's and 149 for the 7200's
