Component Video Cord for Audio?
tecmo04
tecmo04 Posts: 421
So my local bb is putting a lot of stuff on clearance. They had some Monster 1000 component video cords that where normally 110 marked down to 28. I was thinking about buying two sets and us:confuseding them for my 6.1 outs from the dvd to receiver.
Any cons to doing this?
Are video cords different than audio?
Post edited by tecmo04 on
  • obieone
    obieone Posts: 5,077
    edited May 2008
    I'm using 2 RCA a/v sets for the 5.1 SACD out of my dvdp into my rcvr. It sounds awesome to me, but I'm sure some purist will come along and say 'NO!!!!'
  • danger boy
    danger boy Posts: 15,722
    edited May 2008
    if you get sound from point A to point B, that's all that matters.. keep rocking!
    PolkFest 2012, who's going>?
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited May 2008
    Should work fine, other than the fact that 6.1 requires 7 cables, and the two pair you have will only give you 6.
  • tecmo04
    tecmo04 Posts: 421
    edited May 2008
    Ahh, math was never my strong suit. i ment 5.1. So are there any differences in the construction of audio and video cables? Is it just simply that two cords says audio, three says video? There has to be more than that, isnt there?
  • Face
    Face Posts: 14,340
    edited May 2008
    They're 75ohm cables which many companies use for audio interconnects. They'll work, but I can't comment on the sound.
  • broncsrule21@
    broncsrule21@ Posts: 113
    edited May 2008
    what are some reasonably priced brands for audio "only" use. I'm looking to set up my dvd-a/sacd player and want to buy some new cables ( 1ft or 1.5ft). Any recomendations?
    HT-- Denon avr-2808ci,Emotiva UPA-1s, RTi 10's, CSi A6, ERD-1 surrounds, Vizio P50, Yamaha yst-sw300, DVR hr21, 40g PS3, APC-h15
    Downstairs-- Denon avr-3300,Emotiva UPA-2, Toshiba 50" rear projection, Denon 2200 sacd, Emotiva ERM-1s, small Yamaha sub
  • jayman_1975
    jayman_1975 Posts: 672
    edited May 2008
    "signal cable" gets alot of reccomendations on here. I use Audio Art IC 3's. great cables but in a little higher price bracket than the Signal Cables.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • obieone
    edited May 2008
    Almost everyone I've seen on here recommends Blue Jean Cable. I just checked their website and they have 3' six channel sets starting at $95. Can't see them getting any cheaper, unless you go the route I took(see previous post this thread).
    You can also check Audio Advisor, they carry several brands.
    Good luck & happy hunting.
  • broncsrule21@
    edited May 2008
    I ended up getting Acoustic Research PR-136 Pro II's series 5.1. Got them for $29.99. Some places are selling them for around $75.00. they aint high end, but they should do the job!
  • mmadden28
    mmadden28 Posts: 4,283
    edited May 2008
    tecmo04 wrote: »
    I've always wondered the same, and still don't have a final answer yet, however-in my research thus far, I have found that some packaged Left Right Audio and Video cables, although all 75ohms, can sometimes be constructed in different ways. What I mean is the audio may be coax, where the video is sort of twisted pair.-Not sure how to explain it, but a A/V RCA set (actually RCA brand) has a clear outer jacket, so I can see the inner construction method. Not sure how much that would impact sound, but those cables should probably be avoided. I would stick at least with all cables construted in the same way.
    In my searching around, I've also seen that some cables designed specifically for use as Audio Interconnects, have been deliberately designed in different ways, even from the same maker (some coax, some twisted, etc) each apparently with its own merits.
    I've seen some cables with better shileding than others and some with larger diameter copper than others. Some made with silver, and a large variety of dielectric.
    Even though I don't have all the answers yet, so far I have found/assume (with reservations), that the RCA A/V (2 audio 1 video), component sets, Subwoofer cables, Digital Coax, etc all can apparently be used as an audio interconnect. I have no idea whether any are better than another..
    By the way, currently I am using the Monoprice Premium 2's. I don't remember, but I belive I paid less than $20 for a set (6 cables). I use them from my SACD to AVR and from the AVR to my AMP. No complaints thus far
    ____________________
    Pool: Atrium 60's/45's
  • zingo
    zingo Posts: 11,258
    edited May 2008
    monoprice is a good place if you want good performance for a low price, but don't need a "brand name" on your cables or accessories.
    ICs can be made out of either a twisted pair or coax, and both have their place. For my ICs, I use a double twisted pair (four wires in one cable, with two wires carrying the same signal) and I like it a lot.
    "Although nearly all audio-visual connectors, including audio, composite and component video, and S/PDIF audio can use identical 75 Ω cables, sales of special-purpose cables for each use have proliferated. Varying cable quality means that a cheap line-level audio cable might not successfully transfer component video or digital audio signals." http://en.wikipedia.org/wiki/RCA_connector
