Avel Isolation Transformer Enclosure
MillerLiteScott
MillerLiteScott Posts: 2,564
edited May 2008 in DIY, Mods & Tweaks
I made this enclosure to house my Avel Isolation Transformer. It is to tidy up the look of a raw transformer just sitting on the carpet. I now have it inside my entertainment center. I just need a polk audio emblem for the front and to fabricate the top the next time I have my table saw out.
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • strider
    strider Posts: 2,568
    edited April 2008
    Nice box.:D
    Wristwatch--->Crisco
  • MillerLiteScott
    edited April 2008
    Nice Rack:D
    F1nut Posts: 51,750
    edited April 2008
    That's nice Scott. How about a smoked plexi top?
  • MillerLiteScott
    edited April 2008
    I planned on doing a black oak top of course. Not that much to see inside except a big **** toroidal and a couple of leads.
    Question. I hooked it up using both the primary and the secondary winding this time istead of just the primary. The wire sizes are different between the primary and the secondary.
    Do you think that would/could /should make a difference?
    Scott
  • Systems
    Systems Posts: 14,873
    edited April 2008
    Please tell me you are not using banana plugs for 120 volts AC.:eek:
    Well the primary would be the input and the secondary would be the output so can't see how it would work otherwise.It looks like your tranny has dual secondary outputs so you would run them in parrallel.
    Testing
    Testing
    Testing
  • MGS
    MGS Posts: 11
    edited May 2008
    Looks like you configured it with Primaries and Secondaries Parallel Connected as per Avel's diagram for Y23 Range Transformer Connections:
    Left Blade = BLU/VIO
    Left Pin = GRY/BRN
    Right Blade = BLK/ORG
    Right Pin = RED/YEL
    Is this correct?
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2008
    What about a piece of smoked lexan for a top cover?
  • Systems
    edited May 2008
    Doh,:oI must apologize for my ignorance with my previous reply in this thread.I thought originally that Scott meant this Isolation transformer was for 120 volt AC usage thus my comment about the binding posts.I now see it is part of the specialised setup to use SDA's with non common ground amps.I was not previously aware of the need for the transformer.
    Testing
    Testing
    Testing
  • nspindel
    nspindel Posts: 5,343
    edited May 2008
    Scott, this is to make the cable that would allow you to use monoblocks, right? My NAD 2200 is bridgeable, so I'm definitely interested in how it works!
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    nspindel wrote: »
    Even with the A1 I don't think it would be worth it to bridge. Which SDA's do you have?
    Ben
    Ben
  • MillerLiteScott
    edited May 2008
    My amp is dual mono configuration so after consultation with those in the know I used the Avel isolation transformer for my SDA's. I built the enclosure because I thought it was better than just having a 13lb transformer sitting on the carpet with wires attached to it.
    Wala I have something that looks like something and keeps electronics from going poof.
    I actually milled the top for it on Sunday and painted it. To be honest I have not even seen what it looks like with it installed because of where I have the enclosure sitting right now.
    Scott
  • zingo
    zingo Posts: 11,258
    edited May 2008
    Man, that looks great Scott! Way to build something that looks great and has great function.
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2008
    dorokusai wrote: »
    With blue lights on the inside!!!:eek:
    I think the smoked top would look cool. But if it's stuck behind the equipment rack where nobody can see it, then . . . . .
    Carl
    F1nut Posts: 51,750
    edited May 2008
    schwarcw wrote: »
    Gotta go with a clear top in that case. ;)
  • nspindel
    edited May 2008
    ben62670 wrote: »
    Ben
    http://www.polkaudio.com/forums/showthread.php?t=62106
  • MillerLiteScott
    edited May 2008
    Hear is the lid I made for my Avel Isolation Transformer. Nothing special.
    Do you guys think an old school polkaudio emblem would look good or a newer style emblem? I was thinking of putting it on the face.
    I also put some feet on the bottom.
    Scott
  • Face
    Face Posts: 14,340
    edited May 2008
    I would keep it clean and just throw some feet on it.
  • MillerLiteScott
    edited May 2008
    Suggest and you shall receive. Actually Face take a look at my post above.
    Thanks for looking.
    F1nut Posts: 51,750
    edited May 2008
    Looks great!
  • dorokusai
    edited May 2008
    I have an old Polk emblem if you need one.
  • MillerLiteScott
    edited May 2008
    Thanks Jesse.
    Mark let's talk.
    Scott
