What kind of posts do the SDA-2bs have??
I just won a pair of these and need to know if I should get my cables terminated with banana plugs or spades.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Either one will work.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Thanks for the reply you all.Im going to check out signal cable too.SDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I would pick spadesDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I found spades annoying to use on 2B's. The "cups" that the binding posts are recessed in are on the small side. I would also recommend bananas."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
+1 Face
I prefer Bananas to spades. -
Bare wire (12 guage from the hardware store) wrapped around the terminals.
Feed the cable on the left side of the terminal so that as you tighten the terminal to the right, the tightening process wraps the cable onto the post. If you feed the cable from the right side of the terminal then as you tighten the terminal it will result in the cable being pushed off the terminal.
