What kind of posts do the SDA-2bs have??
fbm211
fbm211 Posts: 1,488
edited April 2008 in Speakers
I just won a pair of these and need to know if I should get my cables terminated with banana plugs or spades.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • nspindel
    nspindel Posts: 5,343
    edited April 2008
    Either one will work.
  • fbm211
    fbm211 Posts: 1,488
    edited April 2008
    Thanks for the reply you all.Im going to check out signal cable too.
  • hoosier21
    hoosier21 Posts: 4,420
    edited April 2008
    I would pick spades
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Face
    Face Posts: 14,340
    edited April 2008
    I found spades annoying to use on 2B's. The "cups" that the binding posts are recessed in are on the small side. I would also recommend bananas.
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2008
    +1 Face
    I prefer Bananas to spades.
  • bbeacham
    bbeacham Posts: 141
    edited April 2008
    fbm211 wrote: »
    Bare wire (12 guage from the hardware store) wrapped around the terminals.
    Feed the cable on the left side of the terminal so that as you tighten the terminal to the right, the tightening process wraps the cable onto the post. If you feed the cable from the right side of the terminal then as you tighten the terminal it will result in the cable being pushed off the terminal.
