glass vibration db212
darthlaidherdarthlaidher Posts: 8
edited April 2008 in Car Subwoofer Talk
Post edited by darthlaidher on
  • bigaudiofanaticbigaudiofanatic Posts: 4,422
    edited April 2008
    LMAO you have no idea do you you can not fix that the only way you can is if you put dynomat on the window. IT WILL shatter I promiss you that. I have seen it happen. TO MUCH BASS=THINGS SHAKING LOOSE AND THINGS BRAKING.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • darthlaidherdarthlaidher Posts: 8
    edited April 2008
    if i put dynamat over the window then i wont be able to see out of it right?
    or maybe i could turn the subs around.. would that stop the vibrations?
    scratch that i cant the wires are to short.
    edited April 2008
    It would help with it but will not cure it. The thing about dynomat I was just messing around.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    edited April 2008
    i guess i'll have to rock the block with my hatch window open lol
  • eloplayspoloeloplayspolo Posts: 1,117
    edited April 2008
    lol.... how long have u had those? and how many hours of music have gone through them do u think?
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
    edited April 2008
    i have had those for about 4 days now, how many hours i dunno 20 minutes of music of work every day almost
    edited April 2008
    u might not want to play them so loud yet....
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Greg PetersGreg Peters Posts: 608
    edited April 2008
    If you have more output from the subs than you need, try firing the enclosure upwards (at the headliner) and see if that minimizes the vibrations...output will probably decrease a bit, but it might take enough heat off the rear glass that things don't buzz to that degree.
Howdy, Stranger!
