glass vibration db212
darthlaidher
heres what it looks like.
link to video
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&VideoID=32718000
link to video
Post edited by darthlaidher on
LMAO you have no idea do you you can not fix that the only way you can is if you put dynomat on the window. IT WILL shatter I promiss you that. I have seen it happen. TO MUCH BASS=THINGS SHAKING LOOSE AND THINGS BRAKING.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
if i put dynamat over the window then i wont be able to see out of it right?
or maybe i could turn the subs around.. would that stop the vibrations?
scratch that i cant the wires are to short. -
It would help with it but will not cure it. The thing about dynomat I was just messing around.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
i guess i'll have to rock the block with my hatch window open lol
lol.... how long have u had those? and how many hours of music have gone through them do u think?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
i have had those for about 4 days now, how many hours i dunno 20 minutes of music of work every day almost
u might not want to play them so loud yet....2013 Toyota Prius
Mosconi 6to8 v8 -
darthlaidher wrote: »heres what it looks like.
link to video
If you have more output from the subs than you need, try firing the enclosure upwards (at the headliner) and see if that minimizes the vibrations...output will probably decrease a bit, but it might take enough heat off the rear glass that things don't buzz to that degree.
