$12 speaker tweak
steveinaz
steveinaz Posts: 19,546
edited June 2008 in DIY, Mods & Tweaks
I found a really nice set of 20" x 20" clay tiles at Home Depot this weekend. Using these when you have carpet gives your speakers a solid platform, tightens bass, and improves midrange. $5.46 ea.
Post edited by steveinaz on
  • danger boy
    danger boy Posts: 15,722
    edited April 2008
    good tip.. i'm interested in giving it a try. :) I wonder if it would work for heavy SDA's ? :p
    PolkFest 2012, who's going>?
  • Face
    Face Posts: 14,340
    edited April 2008
    danger boy wrote: »
    Unless they're spiked, it should.
  • Early B.
    Early B. Posts: 7,900
    edited April 2008
    Yep. I use a pair of cutting boards for the same purpose.
    "God grooves with tubes."
  • DollarDave
    DollarDave Posts: 2,575
    edited April 2008
    Has anyone tried this or something similar with a subwoofer? If so, was it good or bad?
  • Deadof_knight
    Deadof_knight Posts: 980
    edited April 2008
    Spike it . I used 3/8 bolts and t-nuts sharpened to a very nice point , and they are adjustable . I used these on my DIYer 10" 18" and my next 15" cabinet Works great and only cost about 3.00 at the hardware store.
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Early B.
    edited April 2008
    DaveMuell wrote: »
    Yeah, that's what this tweak is usually used for. Another alternative is to go to the gardening section of your local HD or Lowes and buy a $5 18" x 18" cement tile and spray paint it black, then place it underneath your sub. Tightens up the bass a bit, especially if the sub is sitting on a raised wood floor.
  • steveinaz
    edited April 2008
    DaveMuell wrote: »
    Dave
    When I had my SVS, it also sat on a tile--I like the tighter bass.
  • steveinaz
    edited April 2008
    danger boy wrote: »
    The tiles I bought were 1/4" thick (Marazzi I believe) and have no problem with my spiked C-9's.
    heiney9 Posts: 25,630
    edited April 2008
    steveinaz wrote: »
    The tiles I bought were 1/4" thick (Merrazzi I believe) and have no problem with my spiked C-9's.
    What department in Home Depot; kitchen, garden, outdoors; flooring? I have been looking for something like this for awhile. Home Depot is huge and I never seem to run across these types of things when I'm randomly looking.
    edited April 2008
    The largest our Home Depot had in stock was 16x16 which I thought was just too small. So I ran across the street to Lowes and they had a couple of 18x18 pieces on clearance so I grabbed (2) 18x18 tiles for $3.70 each = $7.40 total.
    As soon as it stops pouring out I'll bring them in and put them in place. We are going to be having severe storms tonight and tomorrow and the rig will stay unplugged so I'm in no hurry to see how it sounds.
    Great find Steve!!! ;)
  • edbert
    edbert Posts: 1,041
    edited April 2008
    DaveMuell wrote: »
    I did. Mind you I just have a PSW10, but it was sitting on the carpet and I wasn't getting the best sound from it I thought. I happened to have a leftover piece of tile from when the house was built and slid it under there. It was a pretty dramatic improvement from my perspective considering I don't have the best sub placement, it meant I could turn down the sub a little so there wasn't distortion on more bass-intensive sections of music or movies without losing overall impact. This probably sounds a little more grandiose than what you would expect, and your probably right, but for free it seemed to make quite a difference.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • steveinaz
    edited April 2008
    heiney9 wrote: »
    There's a couple of isles dedicated to tile, grout, tiling tools, etc.
    edited April 2008
    I found it but I ended up getting a couple pieces at Lowes since our Home Dept didn't have anything larger than 16x16.
    They look nice and make my 1C's appear level since they aren't diggin in the carpet. I have noticed on some very muddy cd's the bass has improved slightly.
    If nothing else they look nice and elegant under the speakers and I think it's a tweak worth doing since the cost is so low. I hear an improvement but not on every recording is it so noticeable.
  • janmike
    janmike Posts: 6,146
    edited April 2008
    I use tiles under my five stands which are spiked for my LSi's (all 5 for HT).
    Michael ;)
    NORTH of 60°
  • steveinaz
    edited April 2008
    Heinie
    Leveling is another benefit, as is increasing height slightly. The tweak is subtle, but for 12bucks, what the heck. I had to go with 20" because my speakers are 18" deep, and 18" tiles are actually 17 3/4".
    edited April 2008
    steveinaz wrote: »
    Heinie
    I agree, they look much better visually and I do hear some benefit in sound. A win-win situation and I got a great deal at <$8.00 out the door. :cool:
  • atxconnection
    atxconnection Posts: 1
    edited May 2008
    Are you saying this mod is worth doing for spiked speakers? My RTi12 use the plastic spikes that came with them and sit on carpet, would this mod help out? Or should I just use it for my sub (Bic H100)
  • steveinaz
    edited May 2008
    Both. My speakers are also spiked and sit on tiles.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2008
    Do it. It helped when I had my RTi10's.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • DollarDave
    edited May 2008
    I did this with my HSU, down-firing sub and it helped alot. I was able to turn down the volume on it considerably.
    Next I will try it with my LS-90s, but I would not expect as much benefit with those; but, I may be surprised.
  • venomclan
    venomclan Posts: 2,467
    edited May 2008
    Are they THX Certified?
    edited May 2008
    venomclan wrote: »
    My tiles are signed by George Lucas, does that count?
  • scottnbnj
    scottnbnj Posts: 709
    edited May 2008
    i think the idea is that you want your speaks on as solid a foundation as possible. if they can move back and forth in soft carpet or if they cause a more solid floor like wood or laminate to resonate, you're not getting the best performance possible out of them. so, you look to either couple the speakers with or decouple them from the floor depending on your situation.
    most folks mention bass performance, but, if i remember right, i've read to the effect that if you consider the short length of high frequency sound waves and that if low frequencies can propel speakers back and forth even just a tiny bit, that some high frequencies might get cancelled or smeared.
  • Face
    Face Posts: 14,340
    edited May 2008
    I can't find any 24" tiles at the depot or lowes. I'll have to check out some other places.
    edited May 2008
    Face wrote: »
    I couldn't either, but I did find some 18x18 tiles and they work great. Obviously if you need it for a sub you'll need a larger single piece.
  • Face
    Face Posts: 14,340
    edited May 2008
    Those would be for my mains. ;)
    edited May 2008
    Face wrote: »
    Measure and see. I have SDA 1C's and the 18x18 fit very well with about 2" in the front and back and about 3/4" on the right and left as hang over.
  • steveinaz
    edited May 2008
    You'll probably need to go to a specialty tile store for 24 x 24 and bigger...
  • Face
    Face Posts: 14,340
    edited May 2008
    My mains are 26" wide, 18" deep, and 36" tall. My spikes are about 1.5" in all around, so a 24x24 or 24x18 would work perfectly. 20x20 would work for my sub though.
    There are pics in my system showcase.
  • venomclan
    edited May 2008
    heiney9 wrote: »
    You need a new floor...:)
