Need a preamp....any advice is appreciated!
Lightstar1
Sure hope you can point me in the right direction. I want a good preamp for my new setup. I am running a pair of SDA SRS speakers with a Carver 1.0t amp. Probably will get something more powerful later but blew my budget, or most of it, on the SRS speakers. What would you suggest as a good preamp to use....my budget is under 500.00. Saw a Pioneer Spec-1 for sale....is it any good? Please give me your recommendations....I am open to what you think. Thanks!
Post edited by Lightstar1 on
Ask Pearsall001.:DHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Go tubes or go home.
A few suggestions to get you started.
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1213309730
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1212072524
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1213489347Political Correctness'.........defined
President of Club Polk -
2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series -
Going old school with the Spec-1. In 1977 I bought the Spec-1 Spec-4. Totally awesome gear. No remote though. Unless your really into the vintage stuff, you might want to go with something newer. I,ve seen the Rotel RC-1070 going used in the $300-$350 area. Nice, affordable pre.
this one might not be bad at all
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1212636596JC approves....he told me so. (F-1 nut) -
As cool as the vintage Pioneer stuff is (yes, I'm a fan), there's far too many switches, knobs, and other bad things on those preamps that the signal has to route thru.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I have a buddy with an Odyssey Tempest preamp for sale (with remote and separate sub out). It's an excellent preamp (I owned it a while and traded it to him for some speakers he needed to divest himself of due to space requirements). He hasn't listed it yet (he uses Audiogon). Let me know if you are interested. It's right around your budget (no more than $500).
Audio Alchemy DLC
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Sounds like the old Spec1 is not the way to go.....Looks like you guys recommend a tube preamp.....I had not considered that since I have never had any tube gear. How much better or how does the tube preamp compare to the "solid state"??? More suggestions welcome!!
The most noticeable difference after adding a tube preamp into my rig was that the higher frequency "glare" was smoothed out. It took away the rough edges. Before this I was using my HK AVR635 as a preamp.
Lightstar1 wrote: »Sure hope you can point me in the right direction. I want a good preamp for my new setup. I am running a pair of SDA SRS speakers with a Carver 1.0t amp. Probably will get something more powerful later but blew my budget, or most of it, on the SRS speakers. What would you suggest as a good preamp to use....my budget is under 500.00. Saw a Pioneer Spec-1 for sale....is it any good? Please give me your recommendations....I am open to what you think. Thanks!
If you're just looking for a simple preamp there's an Audiosource Pre One in the Flea Market for $100 shipped. Some of the early NAD's are excellent. On the other hand, if you're looking for optical / digital, future video / home theater expansions, etc. you might consider a receiver for use as a preamp.
I used an HK receiver for a while with my Carver amp until I found an Outlaw 950 for $400. There's a lot of ways to go.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I just scored a Carver C-1 off CanuckAudiomart for $160.00 and it sounds great. Also has sonic holography (which I love) good for mm and mc cartridges. Very warm sounding with my Hafler amp. An oldie but a goodie (the pre-amp, the amp, and the turntable are all great old gear).SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
