Carver TFM-35 with SDA-2s
TSWisla
Hello, is this a good combination, I have heard that the tfm carvers are a little lacking in the low-end. Should I look for an Adcom 555 or 5500? Or is there a better am for SDA-2s? Thank you.
Zu Soul Supreme
Coincident Frankenstein mkIII
Esoteric K-07
Esoteric K-07
Post edited by TSWisla on
I've used the TFM 35 on my 1Cs and currently on my 2Bs. I don't find it lacking in bass compared to an Adcom GFA555. The differences between the Adcom and the Carver are pretty stark across the midrange and treble. I liked the Adcom, but prefer the Carver, which to me, seems to throw a deeper and wider soundstage. The Adcom sounded like all the instruments were on the same plane. The Carver is very warm and detailed. The Adcom is neutral to bright and probably more accurate. If you can't audition, then you must decide whether you prefer a more laid back sound.Hello, is this a good combination, I have heard that the tfm carvers are a little lacking in the low-end. Should I look for an Adcom 555 or 5500? Or is there a better am for SDA-2s? Thank you.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Interesting, the folks on audiokarma.org said that about the tfm series, thanks for the info then! I am going to pick one up!Zu Soul Supreme
Esoteric K-07 -
I thought the whole point with the TFM amps was that the extra ohm of output impedance was supposed to roll off the high end and give the bass a little "tube amp tubbiness".
Something else about Carver amps--at least some of them reversed the phase for one channel, then "corrected" the phase by reversing the + and - posts for that channel. This was done so that the two channels wouldn't be pulling simultaneous current from the power supply on shared bass notes: with one channel reversed, one channel pulls from the + side of the power supply, the other side pulls from the - side of the power supply--and so the power supply can be a little bit smaller. I'm not enough of an EE to understand how--or if--that would affect the SDA circuitry in the Polk speakers. -
The best way to find out is to compare the 2 amps. Beware the Adcom GFA5500 is NOT common ground but the negative speaker terminals can be tied together to form a common ground if you go that direction."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Just picked up a mint tfm-35, now all I need are some SDAs!Zu Soul Supreme
Esoteric K-07 -
What general (or specific) part of the country are you in TSWisla? Most of the members here have a half-dozen or so pairs of Polk's laying around.:rolleyes: Maybe someone close will part with a pair.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I live near Chicago, I posted a wtb thread in the appropriate forum, but no luck so far. Thank you.
TomZu Soul Supreme
Esoteric K-07 -
OK Im biased here I love the sound of carver 35s Im with Lazareath ! The 1.2s will move you Midbass that punches you:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Compared to some other amps, the TFM series does not have balls to the wall bass. Of course it isn't lacking in the bass department, but it is not as prominent as it is with other amps [including other manufacturers]. Keep in mind though, the grass is always greener on the other side and when you switch amps you may gain bass but you might lose something else.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
