Carver TFM-35 with SDA-2s
TSWisla
TSWisla Posts: 446
edited April 2008 in Vintage Speakers
Hello, is this a good combination, I have heard that the tfm carvers are a little lacking in the low-end. Should I look for an Adcom 555 or 5500? Or is there a better am for SDA-2s? Thank you.
Zu Soul Supreme
Coincident Frankenstein mkIII
Esoteric K-07
Post edited by TSWisla on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2008
    TSWisla wrote: »
    I've used the TFM 35 on my 1Cs and currently on my 2Bs. I don't find it lacking in bass compared to an Adcom GFA555. The differences between the Adcom and the Carver are pretty stark across the midrange and treble. I liked the Adcom, but prefer the Carver, which to me, seems to throw a deeper and wider soundstage. The Adcom sounded like all the instruments were on the same plane. The Carver is very warm and detailed. The Adcom is neutral to bright and probably more accurate. If you can't audition, then you must decide whether you prefer a more laid back sound.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • TSWisla
    TSWisla Posts: 446
    edited April 2008
    Interesting, the folks on audiokarma.org said that about the tfm series, thanks for the info then! I am going to pick one up!
    Zu Soul Supreme
    Esoteric K-07
  • Schurkey
    Schurkey Posts: 2,122
    edited April 2008
    I thought the whole point with the TFM amps was that the extra ohm of output impedance was supposed to roll off the high end and give the bass a little "tube amp tubbiness".
    Something else about Carver amps--at least some of them reversed the phase for one channel, then "corrected" the phase by reversing the + and - posts for that channel. This was done so that the two channels wouldn't be pulling simultaneous current from the power supply on shared bass notes: with one channel reversed, one channel pulls from the + side of the power supply, the other side pulls from the - side of the power supply--and so the power supply can be a little bit smaller. I'm not enough of an EE to understand how--or if--that would affect the SDA circuitry in the Polk speakers.
    heiney9 Posts: 25,490
    edited April 2008
    The best way to find out is to compare the 2 amps. Beware the Adcom GFA5500 is NOT common ground but the negative speaker terminals can be tied together to form a common ground if you go that direction.
  • TSWisla
    TSWisla Posts: 446
    edited April 2008
    Just picked up a mint tfm-35, now all I need are some SDAs!
    Zu Soul Supreme
    Esoteric K-07
  • Marty913
    Marty913 Posts: 760
    edited April 2008
    TSWisla wrote: »
    What general (or specific) part of the country are you in TSWisla? Most of the members here have a half-dozen or so pairs of Polk's laying around.:rolleyes: Maybe someone close will part with a pair.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • TSWisla
    TSWisla Posts: 446
    edited April 2008
    I live near Chicago, I posted a wtb thread in the appropriate forum, but no luck so far. Thank you.
    Zu Soul Supreme
    Esoteric K-07
  • Deadof_knight
    Deadof_knight Posts: 980
    edited April 2008
    OK Im biased here I love the sound of carver 35s Im with Lazareath ! The 1.2s will move you Midbass that punches you
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
    treitz3 Posts: 20,069
    edited April 2008
    Compared to some other amps, the TFM series does not have balls to the wall bass. Of course it isn't lacking in the bass department, but it is not as prominent as it is with other amps [including other manufacturers]. Keep in mind though, the grass is always greener on the other side and when you switch amps you may gain bass but you might lose something else.
