12V trigger - will a "Y" do?
SlowcarIX
will be triggering the velodyne sms-1 and a power amp from the av processor.
can i use a Y from the avp or do i have to go (avp to sms-1) and (avp to amp)?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
You can use a splitter if you want.
I used to use one of these to trigger two amps. No problems.
http://www.radioshack.com/product/index.jsp?productId=2103422&cp=&sr=1&origkw=1%2F8+mono&kw=1%2F8+mono&parentPage=search -
One thing about using a splitter (and the problem that I ran into) was that some components require a certain level of milliamps. 30 in my case and when I ran a splitter it dropped the out put to about 18 on either side. Not enough to power the trigger.
I think in most cases it would work however.There are two ways to argue with women. Both of them are wrong.
