McIntosh Mono-block Heaven
zingo
Look at these babies on ebay:
http://cgi.ebay.com/McIntosh-MC1201-Amplifiers-Mc-1201-amps-set_W0QQitemZ290221814813QQihZ019QQcategoryZ67786QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
1200wpc with 2.1 dB headroom at 2,4, or 8 ohms. The seller says he used these to drive his Wilson Audio Maxx II with 7 watts a piece; wow. They also weigh 180 lbs a piece if you were considering shipping them.
Post edited by zingo on
Those aren't the Mac Daddys of McIntosh though.
Enter the MC2KW: http://mcintoshlabs.com/products/mcintosh-mc2kw-2000-watt-reference-power-amplifier.asp
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Good greif...
They probably want 50k a piece also.:rolleyes:
I just don't know if I could justify it or not.
Maybe if I was super rich.... -
I just realized, doesn't it look kind of like a toaster?
Probably gives off the same amount of heat."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
That totally looks like a toaster! The heat probably isn't too bad since it's SS, but their 300wpc tube monos could brown your Wonder Bread.
I also like that there is a 8K mark on the VU meter... -
I am just curious wont 8 kilowatts fry your speakers?
In the amp world, when is too much really TOO MUCH? -
The MC2KWs were made to drive the XRT2K speaker system. Massive towers with a zillion drivers. I'd imagine those could soak up over a thousand watts and high voltume. The 8K figure on the meter's probably just for giggles or crazy peaks.
The whole setup consists of 3 pieces. That's only the front piece in the picture.
What happens when you hook up this amp to "everyday" speakers, say a pair of LSi15?:DJohn in MA wrote: »The MC2KWs were made to drive the XRT2K speaker system. Massive towers with a zillion drivers. I'd imagine those could soak up over a thousand watts and high voltume. The 8K figure on the meter's probably just for giggles or crazy peaks.
I'm guessing you don't turn it up as high. But if you can afford two triple-chassic MC2KWs you'd probably get the whole package.
(The picture doesn't do the justice to the size. They're HUGE)
Holy cow!...
i wonder what the losses will be from all the the solder/crimp joints.....my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Blasphemy! This is McIntosh we are talking about!
i wonder what the losses will be from all the the solder/crimp joints..... -
lol! the drivers look similar...
my 7.(1x4) HT setup
Buttkicker
Did someone say something about massive mono blocks?
President of Club Polk -
Damn Jess,those are friggin beautifull !!!HT SYSTEM-
lsi 9's -
That is good price for those. I'm not sure I could stretch the budget for those at this time. The wife wants a new deck.
If your interested in seeing THE McIntosh system, go over to AudioKarma at the Mac site. There is a poster there named Master Lu. He has a system that will nock the fillings out of your teeth. Supposedly he has over $1,000,000.00 invested and still building!2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Those look like mini refrigerators. :eek:Did someone say something about massive mono blocks?
As for Master Lu, his setup is featured on McIntosh's page.
http://mcintoshlabs.com/showcase/default.asp"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
In that second picture I spot a B&W tweeter pod in there! Master Lu hasn't been faithful!:D
mightymouse wrote: »In that second picture I spot a B&W tweeter pod in there! Master Lu hasn't been faithful!:D
That's someone else's setup, it's a typo."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I see.
Very impressive systems. But kind of makes me wonder, with all those amps packed so tight together and in cabinets, aren't there going to be problems with ventilation? -
Hi SlowcarIX,
On a completely unrelated thought: Did you get and hook up your D-Sonic 2500-7 yet? I am curious about how you like it. How is it?
Thanks.Speakers:
. 5.2 surround config:
. . . In-wall L & R Fronts and Center: Polk LC265i, LCi-RTS-C. In-ceiling L & R rears: Polk LC80i
. . . Floor Subs: Polk DSWPro 500, Paradigm PDR-10
. Zone B: very old pair of Polk M 5's
. In Storage but still favored: Paradigm Monitors
AVR:
. Yamaha RX-V863
Universal DVD:
. Oppo DV-980H
TV:
. Sony Bravia XBR LCD 40" 720P (2005 vintage)
. Comcast Cable, Motorola box -
The xrt2k speaker by mac can handle 2k watts but can run on as little as 75. WOW thats alot of watts it can handle.If life had more tubes it would be a lot smoother.
Hi SlowcarIX,
Thanks.
i got the av processor 5 mins ago...but the amp will not be shipped till the 29th
i'll just stare at the system a few days more :mad:my 7.(1x4) HT setup
Buttkicker
I like how they integrate the look of tubes into their McIntosh look; nicely done.
These are sweet too.
I'd like to pick one of these up this year.
I love my Macs!
Mac's rule!!! End of story!!
