Question about DAC Lite AH
SolidSqual
Does anyone know if this DAC can accept a Toslink signal from a Xbox360? Has anyone done it?
http://www.pacificvalve.us/LTDACAHM.html
The website says:
Note: The DAC-AH does not recognize PCM or
LCPM 2 channel material from DVD Audio.
So, I'm not sure if the 360 will work. . .
The website says:
Post edited by SolidSqual on
I wonder if that is more of a bit depth and sampling rate limitation due to the older chip in that DAC. I would think that the DAC could handle 16/44.1 from any PCM source, assuming the xBox can be set to that resolution.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
Yeah exactly. I was thinking the same. My goal is just to have a nice but affordable DAC for the 360. My system as it stands now really pokes some holes in the 360s onboard DACS. . . so much so that it is noticeable during gameplay. I used to have a CA840C which I used as a DAC for the 360, so I know the 360 is to blame.
One watchout on the DAH-ah is the clipping and distortion on hot material with a lot of bass. Games might be a real problem in that regard.
There are a couple big threads on this, maybe at head-fi, don't recall. Supposedly some units were running the wrong voltage to the DAC chip. Folks figured out a couple ways to fix this with some part changes/additions.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
I haven't used my 360 in a while, so I'm only guessing.
Make sure the output is only stereo, and not 5.1. Then you shouldn't have a problem other than what was mentioned above."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
