anyone have $1,395 I can borrow for a CD player?
danger boy
danger boy Posts: 15,722
edited April 2008 in 2 Channel Audio
ok. so I get in my email box today... what has to be one of the most interesting sounding CD player from what it can do and the specs on it. It looks pretty sweet too. not flashy, but what i'm more concerned about is what it's got under the hood :)
here she is... http://www.audioadvisor.com/prodinfo.asp?number=CA840C
PolkFest 2012, who's going>?
Post edited by danger boy on
  • venomclan
    venomclan Posts: 2,467
    edited April 2008
    There has been a lot of info and scandal about the 840 since it came out. You will read reviews across the board. Phil has one and loves it. Solid had one and liked it but just sold it for a Raysonic I believe. It was on my radar, with the exception of it being made by Cambridge Audio. I have had 4 CA units over the last 4 years - 2 640C's a 500SE and a 640H on demo. The 500SE was DOA out of the box, the rest started glitching within 20 hours of use. CA moved all its production to China and QC went to the crapper. The 840 may be the shiznit, but I will not take a chance on CA again.
    Venom
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    I've probably owned about 15 pieces of CA....no issues at all. The 840C doesn't really interest me but it is getting solid reviews.
  • danger boy
    edited April 2008
    is that surprising at all that they would have problems working right?.. they are British for pete's sake :eek: :p
  • pearsall001
    pearsall001 Posts: 5,249
    edited April 2008
    danger boy wrote: »
    Just do it man!!! It's one mean mother humper that is heads above other players costing a whole lot more $$$$$ & then some. Most other players don't even come close to the sound quality of this unit...period! CA also did their homework on this player...it has two digital inputs that you can use to access it's internal DAC's for other sources. Down the road I'm sure I'll be involved with a Squeezebox or similar piece & using the CA 840's DAC's that'll be one awesome set-up.
  • shack
    shack Posts: 11,154
    edited April 2008
    I had my CA D500SE for a while and never experienced any problems with it.
  • Emlyn
    Emlyn Posts: 4,650
    edited April 2008
    My 840C broke last month. The display started fluctuating, and then wouldn't power up at all one day. It's under warranty and back in upstate New York getting fixed. So, I wouldn't recommend buying used. Sounded great when it worked, but I actually find the Perreaux CD player a better match with SDA's.
  • haimoc
    haimoc Posts: 1,031
    edited April 2008
    The reviews seem very impressive with this CD player.
    Can you wait until the tax rebate?.. :)
  • SolidSqual
    SolidSqual Posts: 5,218
    edited April 2008
    Badass player. Needs to be paired with Tube preamp in my opinion.
  • haimoc
    haimoc Posts: 1,031
    edited April 2008
    Zero wrote: »
    Save some coin and get an Ayre CX-7e instead.
    My friend has one. I like its blue-dash led when it powers up. One of the best players..
  • pearsall001
    edited April 2008
    Zero wrote: »
    Very nice player indeed...but not worth the extra $$$$$.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited April 2008
    I have owned a CA 500Se, CA 640c V1 and i currently own a CA 840c. The 840c is a Outstanding CD player.Spearit sound may have Demo 840c's for $1099 with a full factory warranty so you may want to check them out ;) thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2008
    I got a 840C from Del and was a noticeable improvement over the very-well-thought-of Bel Canto DAC2. (smoother highs and vocals, more "air," more SDA)
    I'd say with 2 digital inputs, balanced outputs, a totally dimmable display, the CA 840C CDP is can't miss without dropping some way more serious coin.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
