Pre-outs to tv coax input?
Disc Jockey
I have a Denon 3805. Does anyone know if I can take the preouts from zone 2 along with the composite video output, run it through an rf modulator so that it outputs via coax cable and hook that up to a distant tv to get picture and sound? I am thinking the tv will take the place of an amp and that will work but I'm not sure and wanted to get an opinion before I start messing around.
"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Post edited by Disc Jockey on
There is a really easy way to do that. I have a TV mounted in the garage for controling the stereo and CD player. I use one of these for the video, it has a coax output on the reciever. I also use it for the remote extender to control the setup from the garage.
The picture quality is really good, I don't run audio through mine, so can't comment on that. I have the speakers wired directly. I got mine through ebay for about $35.
http://www.x10videosender.com/ -
The cables already run so it's no big deal and what I want is to be able to watch a different source on the distant tv if need be so that wouldn't work anyway but thanks anyway."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
It's plugged into Zone 2, so I can watch a different source in the garage. That was the whole idea, I wanted to be able to control my CDR-HD1500 from the garage, while the wife watches TV/DVD's in the living room.
But if you have already run the cable one of these should work fine.
http://www.radioshack.com/sm-rf-modulatorvideo-component-adapter--pi-2103095.html -
Yep, that's essentially what I had already. I used the coax out on the Dish receiver in to the kitchen and when we wanted to watch dvd's, I took the coax off the dish receiver and plugged it in to the rf modulator that had the dvd inputs run to it. But with the addition of the ps3, I wanted to use the Denon as a switcher so I didn't have to switch the composite inputs between the ps3 and dvd, I just wasn't sure how the preouts worked. Turns out that works just fine, I was just trying to find that out before I messed around with it, which is a bit of a pita. The only other thing I had to do was make sure I had composite video inputs for each of the sources as the Denon does not convert video signals in zone 2.
All is good for now, just waiting on my amp
