Speakers
bigaudiofanatic
I am woundering what I should do for my rear speakers, the rears are 6*9's but I was reading that they do not reproduce as well as 6 1/2's. What should I do if I go with 6 1/2's I'll go with componets. The car is a 2003 honda civic ex
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
First off, thats an old wives tale.
Way back when oval speakers werent as rigid as round ones so they broke up and distorted easier. Thats not the case today with QUALITY drivers. A good set of 6x9's like the MMC690's are just as rigid as any round cones and wont break up and so you get just as clean a sound as from a 6.5 but you also get the superior low frequency response that you get via the extra cone area of the bigger 6x9.polkaudio sound quality competitor since 2005
Okay next question, speaker baffels crutchfield recomends that I get a set for my rears what do you think.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Worthless. Theyre not sealed, not even close so theyre useless as an enclosure - and you wouldnt want them as an enclosure because theyre way too small. I suppose you could use them to shelter your speakers from moisture and all that but Ive never had a problem with that.polkaudio sound quality competitor since 2005
