LSi25's and Onkyo 605
Rike255
Someone I know owns this combination. He says it doesn't sound very good, the sound is "distorted".
Now I know that the LSi25's are 4ohm rated speakers and the Onnkyo 605 is not 4ohm certified. Is this a major problem? Can he damage his equipment by doing this?
I'm guessing the sound issue is because the 605 isn't powerful enough to drive those speakers.
Thanks for the help.
Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim
Onkyo TX-SR805
Post edited by Rike255 on
Tell him its going to burn his house down. If you don't believe that then use the search function.
The person sounds a little mis-informed to be using $2500 retail speakers with that amp.
Tell him to sell the speakers or get a better amp. He's putting Diesel in a sedan that requires premium unleaded. . .Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
That's what I told him. I said he should stop using them right now until he gets an amp (and as it turns out, a pre-processor since 605 has no pre-outs).
He actually wasn't going to buy those speakers but someone gave him an "amazing deal". Don't know what it was, but he decided to get them instead.
Then when he told me they were hooked up to a 605 I figured that was the problem.Polk Audio RTi8 Fronts
Onkyo TX-SR805
Sony Playstation 3 120GB Slim -
a panasonic theater in a box receiver should work perfectly lol. what about the 805 like you have rikeAudio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Panasonic:TH-42PX60U 42"Plasma
Power Conditioner:
Monster Power: HTS 3600 MKII Home Theater
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
jaysonbarnett wrote: »a panasonic theater in a box receiver should work perfectly lol.
It's funny because its true. The newer digital panasonic receivers work quite well with 4ohm loads, and for a while they did include them in their HTIB systems. -
+1 on comments that a separate amp is needed to make the best out of LSi25s. But I disagree with the comment that you will get distorted sound. I am running LSi15 with 605 for 6 months now and have never heard any distorted sound. I think Lsi25 would be an easier load as they have active sub woofer.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
If he purchased the 25's used (for an amazing deal) maybe one or both of the tweeters are blown....
I would expect bass to be sloppy and perhaps distort at moderately high levels, but they should still sound like LSi's at normal volumes (his AVR is probably running hot as hell though).
If they sound distorted at most volumes - I am guessing at a speaker issue.
