Leather interior
Strong Bad
Strong Bad Posts: 4,278
edited April 2008 in The Clubhouse
What kind of cleaning/conditioning products do you use for leather interior? How often?
I want to keep the interior of my new Accord looking spiffy for as long as possible.
SB
No excuses!
Post edited by Strong Bad on
    VR3 Posts: 29,392
    edited April 2008
    Just leather conditioner at Advance --
    Armor All is way to greasy to put on seats..
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2008
    John, I'd look for something from meguires (sp?)
  • Face
    Face Posts: 14,340
    edited April 2008
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2008
    +1 ^^^^^^
    I either use Lexol or Armor All for Leather. The Lexol is awesome.
  • strider
    strider Posts: 2,568
    edited April 2008
    Yep, Lexol in the brown bottle. Can't go wrong with that.
    Wristwatch--->Crisco
  • Jstas
    Jstas Posts: 14,974
    edited April 2008
    My favorite stuff was from CRC but the label said The Tannery on it. I can't really find it locally anymore but that stuff worked fantastically! You can get it from the site but it only comes in cases I think. Go here: http://www.crcindustries.com/auto/ and look under "Products". When the window pops up, go under Appearance and then look under leather care. There is a ton of different products under there and if you can find the Tannery products, get them, they work great.
    However, get a conditioner specifically designed for leather. The Meguiar's stuff is good and so is the Mother's stuff. I would stay away from Armor All completely. That stuff is a tool of the devil!
    Expert Moron Extraordinaire
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2008
    If you plan on keeping anything, never use Armor-All. It dries out your leather / vinyl and causes cracks.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2008
    Agreed, Armor All is liquid death in a bottle...
  • Face
    Face Posts: 14,340
    edited April 2008
    Armor All is like crack...literally.
  • dkg999
    dkg999 Posts: 5,647
    edited April 2008
    Lexol or Maguires!
    DKG999
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2008
    Strong Bad wrote: »
    SB
    then stop leaving your organic material on the seats while looking at all the lovlies pics as you roll.
    RT1
  • Strong Bad
    edited April 2008
    I agree Armour All is liquid death! I haven't used that crap in a long long time. I'll check out the Lexol. Thanks everyone!
    RT1, gotta have some fun while driving. ;)
    No excuses!
    treitz3 Posts: 19,950
    edited April 2008
    I don't know where to get it, but look into "Lazy Leather". Also, try not to get body oils and salts onto the leather. Wiping with a damp cloth will keep it moisturized and as mentioned before, do not ever use Armor-All.
  • Willow
    Willow Posts: 11,218
    edited April 2008
    I have no info on cleaning car leather, but speaking of cars, I just had ours detailed. Finally got rid of all the winter build up, salt sand....now it smells clean and looks even better. Now I can't wait till the end of this week when the summer tires and alloys go back on. Then it's off for a big clean on the outside. Unfortunatly I have to pay some one to do all of this due to my condition.
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited April 2008
    I also use Tannery leather conditioner. Works great, but I bought my cans years ago before it was owned by CRC. Don't know if the formula is still the same.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited April 2008
    Good question. Thanks for the answers. Just got a new car myself, so I will be checking out some Lexol.
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2008
    I use Macguiars. Also check out Zaino products, some of the best leather, wax you can buy. Literally. I just started with the Zaino, and everyone swears by it on the Cadillac Forum. It literally leaves that wet look on your paint.
  • Face
    Face Posts: 14,340
    edited April 2008
    Zaino works great too, it's just expensive and not as easy to get your hands on.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited April 2008
    Maguiars for me
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2008
    I use Lexol, I tried others but also go back to Lexol its the best.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited April 2008
    I need to treat my seats. I get in and out of my truck @ 15 times a day at least.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Shizelbs
    edited April 2008
    Just ordered a bottle of Lexol.
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2008
    Saddle soap, used for cleaning saddles.
    F1nut Posts: 51,686
    edited April 2008
    Strong Bad wrote: »
    I'd suggest you stop farting in the car and you won't get that hole in the seat problem like in your Ford.
  • SKsolutions
    SKsolutions Posts: 1,820
    edited April 2008
    It appears the Accord has be duly christened. Good thing it's not fabric, you could scratch yourself.
    -Ignorance is strength -
  • MikeC78
    MikeC78 Posts: 2,315
    edited April 2008
    I like using those wipes from Meguire's. I believe it's called "Gold Class" and comes in a handi-wipe container.
  • bassaholic
    bassaholic Posts: 315
    edited April 2008
    Simply use a mild clothes detergent and H2O combo. (Woolilte) After, use Suave hand lotion as a conditioner. This method has been tried and true on SAAB net.com for years. It's also less expensive than leather specific products. Yes...I have tried this and still do.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
    heiney9 Posts: 25,406
    edited April 2008
    Lexol or Xymol. I wouldn't use Suave hand lotion as it's way too sticky and greasy.
    Mink oil (wax/polish) is recommended for leather shoes. I've never tried it in the car but I have used it on a leather couch and chair. Actually I'm going to check into that and will use it this year in the GTI.
    Apply about 3-4 times a month if you car is in constant use. The winter is tough as I didn't condition the leather this winter.
  • Fireman32
    Fireman32 Posts: 4,845
    edited April 2008
    I always used Lexol when I detailed cars.
  • Strong Bad
    edited April 2008
    Oh I'll have a nice one cooked up for you for Polkfest! :D
    No excuses!
