Question about Peerless Tweeters
chrisw302
chrisw302 Posts: 9
edited April 2008 in Vintage Speakers
I have a pair of early monitor 10's with peerless tweeters. One of the tweeters is bad so I have been looking for a replacement. I have found one that supposedly came out of a monitor 5. The guy says that he thinks it is a peerless hf1000. It looks identical to the ones I have except it doesn't have the pin hole in it. Does anyone know if this tweeter is suitable to use with an original one that came for polk? Also if I use this one should I try to put the pinhole in it?
Any info would be much appreciated.
Chris.
Post edited by chrisw302 on
  • Ricardo
    Ricardo Posts: 10,634
    edited April 2008
    I've had peerless without the pinhole in my monitor 7's, and have not been able to tell the difference.
    Have you confirmed that the problem is the tweeter, and not the fuse (if your speaker has them)? Maybe a lose connection, or something in the crossover? Try swapping tweeters and see if the problem follows the tweeter. Double checking won't hurt.
    SOPA
  • chrisw302
    chrisw302 Posts: 9
    edited April 2008
    Thanks for the info. The tweeter is definitely the problem. I hooked another one up in its place and it worked fine.
    Chris.
  • jakelm
    jakelm Posts: 4,081
    edited April 2008
    peerless tweeter without hole, will do fine..
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
