question about inputs
conqur
conqur Posts: 80
edited April 2008 in Electronics
i have a question. this may like something i should know, but i don't. what are the 7.1 inputs on recievers used for?
Post edited by conqur on
  • ben62670
    ben62670 Posts: 15,969
    edited April 2008
    SACD Playback, DVDA, Blue Ray, and HDdvd. It helps with future proofing.
    Ben
  • engtaz
    engtaz Posts: 7,675
    edited April 2008
    Frt Lt & RT,Center,Side LT & RT, Rear Lt & RT, and
    Sub is the .1
    engtaz
    engtaz
  • conqur
    conqur Posts: 80
    edited April 2008
    ok another question, does this mean i can get dolby true hd or dts hd surround sound, if i used the inputs on the reciever.
  • engtaz
    engtaz Posts: 7,675
    edited April 2008
    Only thru HDMI and HDDVD and BlueRay disk or HDCD or HDDVD. There might be more but only thru HDMI cable and HDMI receiver.
    engtaz
    engtaz
  • conqur
    conqur Posts: 80
    edited April 2008
    ok thank you very much.
  • ben62670
    edited April 2008
    Blue Ray, and HDdvd don't process the audio, and send out a 5.1, or 7.1 analog signal?
    Ben
  • Bamadude
    Bamadude Posts: 245
    edited April 2008
    There are some BluRay players coming out with 7.1 analog out that do Dolby/DTS HD as well as DTS Master Audio.
    Panasonic BD-50
    Sony BDP-S550
    AVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE]
