B&k St-202
kobo
Hi, I just got a B&K ST-202 and it does not have the original transformer. Does anybody have a B&K ST-202 to tell me the original specifications?
I know it's 300VA but I don't know the output in volts.
I think it should write on the label of the transformer or you can use a multimeter.
Post edited by kobo on
Welcome kobo,do you know or are the DC rail voltages indicated on the amps circuit board somewhere?If so then you can calculate the AC voltage needed to achieve that level of DC.
Did the previous owner swap the tranny due to failure of the original?Maybe give B&K a call or an email.Testing
Testing
Testing -
I have one downstairs. Give me a couple hours and I'll see what I can read on the toroid.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Well I just so happen to have a PDF showing all discontinued B&K amplifier specs, as any proper B&K fan boy should
You don't mention that it's a plus so here are the specs for the ST-202. About the only thing I left off were deminsions.
Produced: 88-93
Watts per channel: 8 ohms: 150, 4 ohms: 200
Current Peak-to-Peak Per Channel: 28 amps
Dynamic Headroom: 1.5dB
Frequency Response: 5-45KHz
Dampening Factor @50Hz: 180
Input Sensitivity: 1.4v
Input Impeadance: 24K
THD: 0.09%
Slew Rate: 14v/us (per micro second)
S/N: 95dBAVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
He wants to know the secondary voltage of the transformer,do you have a schematic?Testing
Testing
Testing -
Oops, got excited and didn't read the entire post. Sorry don't have a schematic so no help here.AVR: Elite VSX-21TXH
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
thanks for replies, the DC is not written anywhere and I don't know for sure if the new transformer put by the previous owner is just like the original. it's a unitra transformer
Hi, does anyone have the a ST-202 to check the secondary voltage on the transformer please?
