B&W Amp question
dpowell
I'm considering adding a B&K or other brand amp to my setup and using my Sony as a pre-amp sometime in the next few months. It will be my first venture into separates. Does anyone know the difference between a non-reference amp like the AV5000 and a reference series amp like the 7250?
Post edited by dpowell on
IIRC, the topology was pretty close between the two, but the 7250 has twice the wattage, and as a result has a MUCH beefier power supply.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Is there typically a difference in sound quality or is it more about ability to drive speakers without fatiguing?____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Mostly just driving speakers. You get an extra ~3db of headroom w/ the 7250. It was months, maybe years between when I'd heard each, but I don't remember any striking differences. The AV5000 was in a fairly small room and had no trouble going plenty loud.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
