DIY Acoustic panels
AdamRagland
you guys had any luck building your own panels? i'm putting together a list of materials im gonna need to put together a few panels myself. has anyone had any luck finding some corning 703 locally maybe from one of the home improvement stores?
Post edited by AdamRagland on
I bought mine at from http://www.atsacoustics.com/item--Owens-Corning-703-Case-of-6--1004.html. It ended up being $100.00 shipped to my door. Not bad if you ask me.
Good luck with a home improvment store. They might be able to order it for you. But ATS had mine to my door in a couple of days. I think it was $20.00 for shipping. I tryed to find some locally but for $20.00 I figured I would just have them shipped.
Oh by the way. The ones I built worked very well. I think I had around $250.00 total invested and it was by far the best upgrade I have ever made. Period! -
Because OC705-705 is not readily available in Canada I used ROXUL mineral wool for these panels and corner traps.The OC stuff is usually only available from acoustics companys.Testing
Testing
Testing
