LSi15 Crossover frequencies
Just curious what frequencies the lower binding posts of the LSi15 handle vs. the uppers. I'm trying to decide which speaker cables and IC's to put where.... Are the upper's just the tweeter?
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
Yes.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Phono Pre:PS Audio GCPH -
Or -
Top post = 2.4k and up
Bottom Post = 2.4k and down.Mains.............Polk LSi15 (Cherry)
Or -
Works for me, thanks. Incidentally, where did you get this info?Speakers: Polk LSi15
http://www.polkaudio.com/homeaudio/specs/individual/floorstanding/lsi15/my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Correct - with the additional bit of top post only has the tweeter on it....Mains.............Polk LSi15 (Cherry)
Ok, but does that link show specifically which *binding post* ends up at which drivers???Speakers: Polk LSi15
remove the pair of gold plated bridge and you should be able to tell which post goes to which set of drivermy 7.(1x4) HT setup
Buttkicker
No, but I disconnected the jumper between the top and bottom posts on my 15's and hooked up the speaker wire.
Connected to the top post, only the tweeter was playing.....Mains.............Polk LSi15 (Cherry)
Thanks, simple and easy test which I should have thought of, but didn't
