Shanling needs to be cleaned
VR3
VR3 Posts: 29,432
edited March 2008 in Electronics
Lens, etc
What type of maintence do I need to do?
Any tips?
Post edited by VR3 on
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    No maintenance is required on modern CDP's unless it's having read errors or not playing media.
  • MikeC78
    MikeC78 Posts: 2,315
    edited March 2008
    Soap and water.
    I'd just blow the dust out with a can of compressed air.
  • haimoc
    haimoc Posts: 1,031
    edited March 2008
    Yes, many people recommend to pop out the case and use compressed air to blow the dust.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2008
    Eat some mashed potatoes, then lick the lens and laser assembly. Wipe off with the corner of your T-shirt.
  • Early B.
    Early B. Posts: 7,900
    edited March 2008
    Stop playing those dirty CDs.
    "God grooves with tubes."
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2008
    Just clean the dust out.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited March 2008
    RuSsMaN wrote: »
    I thought you were supposed to eat peanut butter first.:confused:
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited March 2008
    It's obvious: you need new speakers. ;)
    tonyb Posts: 33,072
    edited March 2008
    Bath tub....scrub brush....make sure you get behind the tubes.:p
  • rskarvan
    rskarvan Posts: 2,374
    edited March 2008
    I've got a Denon DVD-3300 player that is getting VERY PARTICULAR regarding movie DVD's. I think the laser is getting weak with age and it is skipping. So, I'm struggling whether to send it back to Denon for a laser replacement... or, just chuck it and buy something else. New, the Denon DVD-A player sold for an MSRP of $1200. So, its not exactly disposable. Advice?
  • dorokusai
    edited March 2008
    Send it back to Denon.
  • Early B.
    edited March 2008
    Chuck it and buy a used $50 HD-DVD player. You won't miss that Denon if you do.
