Quad 405 amplifier
ben62670
Anyone ever get their ears on one of these? They are a pretty simple design. Currant dumping. The price for 2 boards was about $20 bare. My old JVC receiver has a transformer that puts out near ideal voltage for it. So I decided to build a fun little cheap project. A few guys have modded these to remove the currant limiting, and use better TO-3 trannies (which I already had). Its going to take some time due to lack of funds, and it is so hard to find suppliers that have all the pieces in one store to purchase. This kills the super cheap build price BTW.
Ben
Ben
Post edited by ben62670 on
Haven't heard em but they are a classic design.I bet Selfs audio pages will have detailed info on the current dumping circuit used.Testing
Testing
Testing -
I'm hot rodding one right now.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Here is a linky for you.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=109771
Did you get to hear it before, or was it broken?
Ben -
I have all the schematics and mod information. I didn't bother since the caps were bulging a little. It's just for fun.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
May I ask where you scored the blank PCB's from,was it a group buy?Also I dont have win zip so cant see the schem that was posted.It certainly looks like it is low parts count for an amp.If I could get the PCB's I d like to built a pair of channels.Testing
Testing
Testing -
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350029485751&ssPageName=MERC_VI_ReBay_Pr4_PcY_BIN_Stores_IT&refitem=350039899477&itemcount=4&refwidgetloc=active_view_item&usedrule1=CategoryProximity&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=its%3DS%252BI%252BSS
This is where I am starting from. The inductors are the hardest things to find.
They are getting silly money for a 70's vintage amp on ebay.
A search for quad 405 brings some up. One is going for almost $1500 NIB. It seems like $400 is the going price. Well I figured a cheap n easy project to play with.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
So they came from China.How long did they take to arrive?I have some 2mh coils that might be fine for use in that output filter.I cant see the schem,what value is stated for the coil?Testing
Testing
Testing -
About 30 days. I emailed the guy, and a few days later they showed up. I don't know if I was lost in the shuffle, or what. If you do decide to build it I have some beta matched outputs I can send your way.
I do however recomend this
http://cgi.ebay.com/STEREO-AUDIO-POWER-AMPLIFIER-KIT-BASED-ON-QUAD-405_W0QQitemZ350039899477QQihZ022QQcategoryZ39783QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
then doing the mods.
This guy has great prices on power caps, transformers, and jacks.
http://www.apexjr.com/capacitorsR.html#Computer
I just check there every once in a while to see whats new.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks Ive got you covered for filter caps (15000,63 volt) if you need em.I see in the pic each board has three coils,what are the values? And what are the DC rail voltages?Sorry for all the questions.:)If you do decide to build it I have some beta matched outputs I can send your way.Testing
Testing
Testing -
You might need those caps for your self. The rails are 50vdc L1 is 6.8u L2 is 3u, and L3 is 6.8u.
Ask away. I am getting some cables finished so my responses may be a little slow.
I can email you the PDF with the modded components. It is actually less components with the mod than without. The Original TO-3's probably couldn't dissipate the heat the newer ones can so you can drop the currant limiting right out, and the signal transistors have higher gains so they recommend omitting one set of trannies. The design is 100wpc 8ohms class A upto the output stage.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Sure Id appreciate that.As for the coils I'll check my Digi key catalog and see if they have them.I can email you the PDF with the modded components.Testing
Testing
Testing -
Thanks Ben for the pdf.It looks like a nice and simple design made so mainly by the use of the IC op amp for the input stage and only two output transistors.However I may opt to build an Aleph 3 (or 5) instead as it also has a fairly low parts count.It will depend on how hard it is to source some the parts.Testing
Testing
Testing
