Linn / Icepower power amp
SlowcarIX
SlowcarIX Posts: 887
edited April 2008 in Electronics
what is the difference between the linn klimax amp vs. the b&o icepowered amps?
http://www.linn.co.uk/music_systems_klimax_500_solo
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    I thought the Klimax was a class A/B with a SMPS (Class H?), while icepower was class D. You can't really directly compare a single amp to a technology, as icepower comes in all sorts of flavors. The 1000asp would be comparable, but then different brands do their own thing giving different sonics even though it is the same amp at heart.
  • bknauss
    bknauss Posts: 1,441
    edited March 2008
    Icepower amps have gotten rave reviews, even from traditional tube guys who love those dynamics. Class D doesn't mean flat sound... its just easier to have flat sound because its a much more complicated beast than a tube or solid state AB amp.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • venomclan
    venomclan Posts: 2,467
    edited March 2008
    A disadvantage of Class D from a lot of sources I spoke to, is that they have a lot of trouble with resistance sweeps. If you have speakers that dip a lot in the ohms area, it can be a problem.
    Venom
  • SlowcarIX
    edited March 2008
    Do the LSi15/LSiC dip very low?
    my 7.(1x4) HT setup
    Buttkicker
  • unc2701
    unc2701 Posts: 3,587
    edited March 2008
    B&O Icepower amps are Class D, done right. That Linn is a class AB with a power supply along the lines of a class G.
    Backburner:Krell KAV-300i
  • Systems
    Systems Posts: 14,872
    edited March 2008
    unc2701 wrote: »
    Yep, them and Hypex UCD,s are the best examples of the breed.
    Or maybe a full PWM switching supply?
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited March 2008
    SlowcarIX wrote: »
    They're 4 ohm speakers to begin with. I believe the 15 may dip down to 2 ohms.
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2008
    gotta love the icepower, the D-Sonic stuff es muy fantastico
  • SlowcarIX
    edited March 2008
    Sherardp wrote: »
    i just got a lsic saturday and was looking for a mono amp to drive them...decided to go with d-sonic m250m from dennis after looking around a bit. ships this thurdays, cant wait to see what it sounds like :D
    my 7.(1x4) HT setup
    Buttkicker
  • unc2701
    edited March 2008
    Funny- I just got a 500asp module for my LSiC. The wife banned the front L&R speakers from the den, so I'd been running my LSiC on one channel of the bryston 9b- TOTAL overkill. So when I saw an Icepower 500asp up on Audiogon, I snagged it. Right now it's kinda ghetto-wired, but still sounds great. Had it up & running in about 10 minutes. At some point I'll do a real review.
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    You bought just a module? What did you have to do just add connectors, power and a case?
  • SolidSqual
    SolidSqual Posts: 5,218
    edited March 2008
    I love my Bel Canto S300s on my Emmys! But, I will tell you that I ran a PS Audio Trio A100 with Acoustic Zen Adagio speakers and received less than stellar results. The A100 on Lsi15s was breathtaking. If I remember correctly, I described it as the first time I ever heard liquid audio.
  • unc2701
    edited March 2008
    Gaara wrote: »
    Yep, but I haven't gotten to the case yet :)
    And by power, I mean I had to add an IEC connector. I might mod it at some point, but I'm pretty happy as it stands. I'll try to get pics up at some point.
  • venomclan
    edited March 2008
    SolidSqual wrote: »
    That is weird as the LSI15's should pose a more difficult ohm sweep than the ADA's. Ice does not do well with those dips. My buddy has a truck subwoofer that sounded great with the Trio A100 I lent him. Maybe your Trio was bad...
  • SolidSqual
    edited March 2008
    No the trio wasn't bad. Didn't I sell that thing to you? I think the synergy was just off. In terms of ohm sweeps, I never felt the Trio was underpowered and I drove it fairly hard now and again.
    At any rate, my new speakers have a 100 db efficiency so ohm sweeps or no ohm sweeps is really not a problem. My current setup is very dynamic. I think like any system, you need to strive for synergy. Some gear is just not going to work well with other gear whether for more technical reasons or sonic signatures.
  • venomclan
    edited March 2008
    SolidSqual wrote: »
    Yes, but I paid you with a Nigerian check.
  • Systems
    edited March 2008
    unc2701 wrote: »
    Funny- I just got a 500asp module for my LSiC. .... So when I saw an Icepower 500asp up on Audiogon, I snagged it.
    Nice snag the modules themselves are usually hard to find.I had the good fortune of getting an asp25O for subwoofer duty.
    Yep simple as it gets to hook up as long as you have the multi pin molex connector for the inputs,I didn't.If you are not using a balanced connection I would recommend shorting the inverted input pin to ground.
    Testing
    Testing
    Testing
  • unc2701
    edited March 2008
    Yeah, they are hard to come by. There were some 1000asp's on A-gon not too long ago for a pretty good price... hate that I missed those.
    The one I got came w/ the molex connectors attached to test leads (except for the power cord & an XLR input) Made it easier to get things going. Already shorted the -V... just took some 12awg house wiring, bent it into a U and plugged that in the XLR. Did the trick :)
    Once I find some speakers that the wife approves of, I'll go back to the bryston & probably put this guy on a subwoofer.
  • venomclan
    edited March 2008
    unc2701 wrote: »
    Are you talking about the Gallos?
  • unc2701
    edited March 2008
    Nah, the Gallos are in the man room- I can do whatever I want in there.
    This is for the den... The LSi9's looked nice enough, but the cat kept on jumping on top of them and almost knocking them off the stands, plus where I had to place them didn't work too well for the 9's.
  • venomclan
    edited March 2008
    Whew, I am never coming out of my man room. :)
  • Systems
    edited March 2008
    Zero wrote: »
    They will never be capable of extracting what the topology is capable of because they are already way too handicapped by weak power supplies, humiliatingly low capacitance, and cheap parts (specifically the B&O ASP modules).
    Switching supplies don't require the typical large storage capacitances used in a regular linear supply.However I think Hypex's choice of using a large linear supply does allow its Class D modules to perform at their optimum, while maintaining their 90% eficiency( the penalties being increased size,weight and cost vs a switching supply like B&O use.)I have a pair of Hypex UCD 180's and one ICE asp250 serving as subwoofer amps which they do admirably.In direct comparison to my Bryston amps driving my main speakers the UCD's even with a big linear supply,lack the refinement of the class A/B design.
    Testing
    Testing
    Testing
  • SlowcarIX
    edited March 2008
    Zero wrote: »
    Tiny class D power amps can be capable of performance that extends well beyond what one would expect from such a fly weight chassis. Whiz-bang audiophile tricks are their specialty; swooning virgin ears with detail, perceived transparency, and control.
    Yet at the end of the day, you can't skimp on the basics; which most of these products do. They will never be capable of extracting what the topology is capable of because they are already way too handicapped by weak power supplies, humiliatingly low capacitance, and cheap parts (specifically the B&O ASP modules).
    If you want to play with the big dogs of the game; you've gotta give the circuit what it needs to strut its stuff. As it stands now, with now being today, the greatest notoriety of class D amps is the startling good bang/buck and form/function roles. It's just a shame to see nearly an entire genre of product being herded in this general direction. Thankfully though, among the Bel Canto's, PS Audio's, Rotel's, et all - reside a few shinning gems that reflect what class D can do when done right.
    even jeff rowland is using these b&o icepower modules...maybe they deserve more credit that you give them?
    http://www.jeffrowland.com/M501.htm
    my 7.(1x4) HT setup
    Buttkicker
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    Zero likes Icepower just fine, he just doesn't seem to like the smps power supplies the asp modules use. He owns a H20 amp which uses icepower with a massively overbuilt power supply. His own review of the unit can be found here on AffordableAudio.
    I respect Sean's opinion a lot, I purchased my speakers (Rothschildes) and amp (SM-70) for my PC rig based on his recommendations. I do however really enjoy the icepower amps using the asp modules, my current main amps using modded 1000asp modules. If that makes me a virgin audiophile so be it.
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    Zero wrote: »
    GV27,
    Gaara,
    Ok, so you're not a virgin. You just haven't had a great class-D experience yet! :p. In all seriousness, a lot of my discontent with the B&O ASP series has less to do with the modules sound quality, and more to do with the ridiculous pricing some companies come up with that use said modules.
    Completely agree. I don't see how Bel Canto can charge $2000/pr of their M300s, when Red Dragon sold their Amp-1s (same module) for $500/pr. You can get Murano monos for $600/pr, I doubt there is much of a difference in sound quality between the 3. Nothing against Bel Canto, most of the larger mfgs seem to price like this.
    One of these days I would like to try some icepower using the asc modules with a big beefy power supply. Not anytime soon though, prices are a little out of my budget.
  • Systems
    edited March 2008
    Zero wrote: »
    GV27,
    You're absolutely correct. Efficient class D and op-amp based amplifiers do not necessarily require big linear power supplies to deliver the goods.
    Just to clarify what I meant in my original post. Switched mode supplies such as the integral ones used on the B&O 250asp and 200asc do not require large filter capacitors because they operate at high frequencies, were as a linear supply is operating at 60hz(120hz ripple) so filter capacitance requirements are greater.I don't understand Audio Sectors reasoning for using such relatively small filter caps on their LM3785 amps.With linear supplies bigger is better.
    Testing
    Testing
    Testing
  • Gaara
    Gaara Posts: 2,415
    edited April 2008
    GV#27 wrote: »
    I always thought that was the point of gainclones, to have as few parts as possible for cost/sound quality, less is more thought process.
  • Systems
    edited April 2008
    Gaara wrote: »
    Audiosector use relatively small filter caps on their commercial LM3875 units. However the use of bigger filter caps,while maybe adding a few dollars to the cost and taking a bit more room,they would not add to the complexity of the design but would boost performance.
    Im not saying they sound bad ,just that they could improve even further by beefing up the supply.Im currently using a pair of Audiosector LM3875 kits (with big filter caps)to power my Vifa 2 way PC speakers.IMO they sound very good.
    Testing
    Testing
    Testing
