Orig. XP Pro & other concerns
obieone
I'm getting ready to build an HTPC, and want to use an old copy of XP Pro from an old custom built pc from 5 years ago.
My question: Will an non-updated version 'see' the hardware long enough to for me to load the drivers, get SP2, etc?
Attached is the shopping list of components off Neweeg. The BRD/ HD dvdp combo drive probably won't be staying.:(
Post edited by obieone on
Without a doubt it will work and get your computer online. Install all your hardware drivers first, then do the SP2 upgrade.
I guess it doesn't really matter, but I like having all the drivers installed first. -
I don't remember exactly what it was, but the last machine I built (about 2 years ago) required SP2 in order to install correctly. It was possibly the Raid, or maybe something with the video card, I just don't remember. But I had to slipstream a SP2 CD in order to install XP.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Thanks BL! Yeah, I plan on loading the OS 1st, then the drivers, then updates. I was just concerned that the older software wouldn't read the hardware.
I'll probably be humping your ear for tech support when I go to light off:D
Now get back to studying so you can get your pigskin...er, sheepskin,...whatever it's calledI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Dang, that seems a bit like overkill for a HTPC! Should be sweet, though.
Have fun with it!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Obieone....
The original version of XP will not recognize large hard-drives. I think it is limited to 250G or so for the C:\. There are some very confusing work-around's for this issue... but, a modern hard-drive will format... but, it won't format to its full capability. So, you'll have to partition the hard-drive and that may or may not be ok for you. Personally, I dislike partitioned hard-drives but, I've learned to live with the compromise.
One thing that you can do is pay Microsoft for a replacement XP Cd (claiming yours was damaged) and it will come with SP2 already imbedded. That's a reasonable fix as well but, I think it will set you back $35 or so.
Good luck with the new puter project. -
You should break up the hard drive anyways partition wise it makes backups easier and safer in the wake a of a breakdown.:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
With my limited experience, I don't lke partitions, because when I want to reformat, I only can reformat from that partition on. I want to be able to 'wipe' the HDD when reformatting. I'm sure I'm not explaining it correctly, but that's the experience I had when I wanted to format my last custom pc.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Create your own XP CD with SP2 by slipstreaming it.
http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp -
Is it 64bit? If not you have no reason for 4GB RAM, 32 bit can only see 4GB TOTAL - this includes video memory etc.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
Just to clarify, XP 32 can only see 3 gigs of memory on the mobo.Is it 64bit? If not you have no reason for 4GB RAM, 32 bit can only see 4GB TOTAL - this includes video memory etc."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I thought there was a patch? Maybe that's just Vista...God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
