TDS True Dimensional Sound or Hughes SRS
Systems
Has anyone owned or had expierience with any of the following sound field processors?any of the TDS units or the Acoustic Research TDS202,Hughes AK100 or NuReality VIVID VHT200?If so were they effective or where they too subtle to be worth using?I would be interested in hearing your impressions.
Testing
Testing
Testing
Testing
Testing
SoundCity used to give away the Nureality units with certain purchases years ago. I got one with something I ordered there.
The result is not subtle, it made everything sound extremely fake, ruined the soundstage, and it added noise. I gave mine away in less than a week. -
Thanks William,It seems the results you got were what one would expect from the cheesy DSP modes available in HT recievers.I'm looking into these specific units as I thought they would be much better than the DSP dirived mumbo jumbo.
My intent is to use it on the rear channels only in a 5.1 HT setup ( no 7.1 capabilities yet).Im locked into a pair of inwall surround speakers in the back wall and was hoping that with one of these processors I would gain abit more soundstage size and envelopment with surround effects.Testing
Testing
Testing -
There were two models available from both Hughes and NuReality. I had every one of them. I still have the more expensive Hughes AK-100 and NuReality machines. If those stores were giving something away, dollars to donuts it was the cheaper models, which were clearly labeled in the marketing literature as "not intended for VERY revealing sound systems". The more expensive machines can be fun, and can add a certain amount of presence and crosstalk cancellation, that wouldn't otherwise be available in a non-SDA sysytem. They add almost zip in the way of noise. This is all moot in a home theater/multi-channel rig.
No experience with the AR unit but I don't think it was a inter-aural crosstalk cancellation attempt. More like a Barcus Berry BBE Sonic Maximizer thing. -
George, would it be remotely comparable to the Carver sonic holography?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Much more than remotely associated. I have the AK-100 in case I ever run out of C-9's. Does that answer your question? The expensive NuReality is almost an exact electronic knock-off of the AK-100, it just doesn't have the cool-man graphic sound-field display on the front. They are both much more adjustable than a C-9 also.
I'm out of here, I gotta fly in the morning. -
Have a safe trip. Thanks.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Thanks George for the informed reply.Im kicking myself for letting an AK100 slip by me on ebay earlier today,it sold for $48.:mad:I think it would be my first choice and would do what I want ,if I can find one.I excluded the C9 from consideration because it has a rather narrow sweet spot.I want there to some benifit even if seated off center.Testing
Testing
Testing -
I use a C-9 cause there's only one seat in my He-Man Rig room. Anybody sitting off-center is on the floor, and I don't care about them. I'll talk to you more about the AK-100 when I get home from work.
I still have this one, can send it your way if your interested.
http://www.polkaudio.com/forums/showthread.php?t=7408&highlight=NuReality
RussDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Hehe thats how it should be for 2 ch,but I figure with HT it would be nice to share.George Grand wrote: »I use a C-9 cause there's only one seat in my He-Man Rig room. Anybody sitting off-center is on the floor, and I don't care about them.
Ok.I'll talk to you more about the AK-100 when I get home from work.Testing
Testing
Testing -
Maybe,I have never seen one so I have a couple of questions. Does it have multipule inputs?If so can those inputs be changed via remote or does it just operate the effects adjustments?Also how big is the chassis of this unit?I still have this one, can send it your way if your interested.
ThanksTesting
Testing
Testing -
let me dig it out, I think it has hook ups like an EQ would have, through the tape loop (or between your preamp and power amp), and it had a tape loop.Dodd - Battery Preamp
I found an Ebay store with some brand new old stock Spatializer HTMS 2510's.They use a process similar to the SRS units,plus it is fully remote controlable.I think I will shoot him an offer and see.Testing
Testing
Testing -
I had a Spatializer also. It had three settings. The one with the least amount of effect was the best. The others were unworldly. I don't remember it having a remote, but I bought it for my daughters when they were very small. I may never have taken the remote out of the box.
Wow Goerge you've certainly had your fair share of audio toys.Yes it does come with a remote.Testing
Testing
Testing -
Well, that one was a toy for my daughters.
