Bi-wiring
tinman67gz
tinman67gz Posts: 15
If I want to bi-wire my Polk Monitor 40s do I need the same size wire for the driver as for the tweeter? Do they both connect to the same term on my reciever? Whats the best size wire for each?:confused:
Post edited by tinman67gz on
  • carpenter
    carpenter Posts: 362
    edited March 2008
    Hi, Welcome :)
    do I need the same size?
    In principle you can get away with different gauge for upper and lower posts, but I fail to see what you're truing to accomplish by it.
    Do they both connect to the same term on my receiver?
    Yup. that's the point in biwire. both '+' jacks on the speaker go to the amp's '+' jack, same for the '-'.
    The longer the wire you need to run, the thicker you want it to be. I guess under 70-80 ft you should use 16 gauge, any longer, say until 180-200 ft go with 14, and above that, even 12 or 10.
    "If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'"
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    I would not bother BiWiring the monitor series. Standard speaker wire from Walmart in the auto section would be fine for them. 14, or 12ga.
    Ben
  • Deadof_knight
    Deadof_knight Posts: 980
    edited March 2008
    Either works great Ive hooked up plenty with the Wally world wire!!! If it were me I would use the same gauge High and low !!!!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
    treitz3 Posts: 19,958
    edited March 2008
    Tinman, bi-wiring is overrated with the exception of two or three folks that swear it made all the difference in the world. To each his own, I guess.
  • tinman67gz
    edited March 2008
    Make it four. I bi-wired my speakers and the highs do sound much crisper and cleaner than before.
    tonyb Posts: 33,068
    edited March 2008
    Five.......I noticed a difference...slight,but there none the less.
  • janmike
    janmike Posts: 6,146
    edited March 2008
    I have found that some speakers do and some speakers do not benefit from bi-wiring.
    Michael ;)
    NORTH of 60°
  • MKZ
    MKZ Posts: 1,068
    edited March 2008
    Use jumpers. Or extra piece of speaker cable instead of oem.
  • xandra
    xandra Posts: 291
    edited March 2008
    Six... I had a huge improvement (Onk 705/RTi10s) but by using both Front and rear surround terminals (still dunno if this is biAmpling or biWiring). I really hadn't expected much, so was very pleasantly surprised.
    I've wonder whether results also vary based on Reciever: how underpowered is it and how does it reallocate the power.
    nonetheless, it's so simple to try, it's worth a stab. (if results aren't an obvious improvement, you can always go back to old setup.
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • ben62670
    edited March 2008
    xandra wrote: »
    Bi-Amping;)
    Ben
