Windows Media vs. Winamp
License2ILL
License2ILL Posts: 71
edited November 2010 in Music & Movies
Did replays and replays of:
Lost boys "cry little sister"
Rick James "Superfreak"
Corey Hart "wear my sunglasses"
Billy Idol "Rebel yell"
Ice T "I'm your pusher"
Jay-Z "Lost one"
Pumped through my classics: Roland MA-8's
WinAmp is doing something...not leaps and bounds ahead of WMP but something......on "wear sunglasses" you can hear a lot more clearly the switching from L-speaker to R-speaker(beginning of song). Overall slightly crispier...and the EQ seems more precise.
Visualz are off though not in tune with the music.
You can run both apps together but I'd stop them before switching back and forth cuz you could crash your junk if you play over each other....they can play together but i dont know how long.
The SL2000wc wow what a predicament!!!!!:D Order one today.......1-800-429-5423 for direct orders with anyone of the elite ee guys that frequent this forum.
Post edited by License2ILL on
  • Face
    Face Posts: 14,340
    edited March 2008
  • Refefer
    Refefer Posts: 1,280
    edited March 2008
    I'm not so sure this should be a redirect. It sounds to me like it's a review of Winamp.
    Were you using ASIO drivers?
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • jakelm
    jakelm Posts: 4,081
    edited March 2008
    Winamp has 10 times the audio codecs compared to WMP.
    All I use is Winamp. Better search, track listing and playback quality.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • License2ILL
    edited March 2008
    Refefer wrote: »
    No what are those?
  • engtaz
    engtaz Posts: 7,669
    edited March 2008
    Winamp
    engtaz
    engtaz
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    New convert to winamp, and I love it. Sounds much better than WMP.
    Ben
  • Refefer
    edited March 2008
    No what are those?
    Basically, whenever you play any music in windows, it has to go through Window's K-Mixer which down or up samples everything to 44.1, 16-bit. Even if you're playing audio which is already in that format, it will reconvert it. The end result: windows screws with the audio before it hits your sound card. ASIO drivers lets you bi-pass window's internal mixer and go strait to the sound card (assuming it supports it).
    Basically, it makes it sound even better ;)
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • honda cber
    honda cber Posts: 267
    edited March 2008
    foobar 2000 is good too--- lightweight and supports virtually every format. i still use winamp a lot if only because i have been doing so for better than 10 years.
    http://www.foobar2000.org/
    a
    gear list:
    1 down, 4 up....
  • mightymouse
    mightymouse Posts: 254
    edited March 2008
    I use foobar 2000.
  • phipiper10
    phipiper10 Posts: 961
    edited March 2008
    I use Winamp - WMP tries to do too much checking or loading or something at startup and ocassionally freezes
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • Meeks32
    Meeks32 Posts: 330
    edited March 2008
    How is winamp vs. itunes? I like itunes better than WMP, but havent used winamp in a long time.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2008
    I think They both suck.
    But knock yourself out.
    RT1
  • Refefer
    edited March 2008
    Winamp is lighter than iTunes and sounds better IMNSHO. The skin it now uses (obviously you can change it) has a a more WMP/iTunes feel about it, so it might be worth checking out for you.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • wayne3burk
    wayne3burk Posts: 939
    Yeah - I prefer Winamp over iTunes too
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
