NTB: Surge protector... I think...
MrNightly
Ok. Was thinking with all this fancy gear these days, I really should be protecting them better then a 8plug power/surge bar... right? Anybody have recommendations for a fairly inexpensive surge protector?
Not looking to break the bank, say, under $100 most likely. Are the cheap monster one's at BB worth it? Anything else I should look for in one?
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
I like the Panamax product line. Furman has gotten some good buzz as well.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Ok, I'll bite.
Anybody have one they wish to unload at a reasonable price?
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Rotel RB-985 5-Channel Amplifier -
Nobody has one sitting around collecting dust they wish to unload huh?
Pity.
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
There was a thread on this one earlier. Will this do the job?
http://www.buy.com/prod/pureav-ap11000fc-10-10-outlet-pureav-home-theater-power-conditioner/q/loc/111/202352763.htmlShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Try to find a used Belkin PF60. They can be purchased new for around $200. I really like mine.
Venom -
Get one of these:
http://cgi.ebay.com/PANAMAX-1000-SURGE-PROTECTOR-LINE-CONDITIONER_W0QQitemZ260222892297QQihZ016QQcategoryZ67781QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I had one for 5 years, very good device, will clean up visual artifacts on your screen as well as clean up your sound.
the 1000+ should sell for no more than $60 to $100
i have three of these,they are great.I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it' -
Get one of these:
Sweet. Will pick one up. Thanks for the recommendation.
CheersHonoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
