REALLY DUMB Wiring Question
xandra
xandra Posts: 291
After stripping the some speaker wire, I noticed a plastic 'thread' - should I cut this off? or is it intentional (didn't look like an accidental strand as it seemed to be a perfectly formed diameter)
I've never noticed this in any other wire I've stripped (its some some basic 14g Monster only brand available in my local store)
Do I win anything for the dumbest question? Points, a free set of LSi9's, anything...
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
• 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Post edited by xandra on
  • hoosier21
    hoosier21 Posts: 4,418
    edited March 2008
    I cut it off also
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Montoya
    Montoya Posts: 506
    edited March 2008
    just cut it it is used to strip the wire pull the string towards the wire away from the cut portion and it will expose the wire more.
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2008
    Yes, cut it off. It's just used to help to strip the wire away, I always cut it off.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • zingo
    zingo Posts: 11,258
    edited March 2008
    And you wonder why a lot of people don't like Monster; their stuff is always more expensive and complicated than it has to be.
  • mmadden28
    mmadden28 Posts: 4,283
    edited March 2008
    There are two kinds of "plastic" thread xandra could be referring to.
    1.) The fiber thread that is usually just under the outer jacket, and usually only in wire meant to be run in walls or plenum spaces.
    As Montoya said-this would be used to expose more of the indivudually insulated wires.
    2.) The plastic 'thread' within an individual wire in the center, surrounded by the copper.
    This is Monster's Magentic Flux Tube, as they mention any chance they get. I am sure other manufacturers probably have something similar.
    Anyway, if your wire is Monster (XP?), and #2 is correct, I just cut it off. If anything I would imagine that it would cause a problem with a good conductive contact with a peice of plastic in the way.
    3.) Same as #2, except when the technology is finally released, you will connect the plastic thread to a Flux Capacitor-which is used to aid in time travel. Consider it looking ahead-if you want to future proof your home... ;)
    -Madden
    ____________________
    Pool: Atrium 60's/45's
  • xandra
    xandra Posts: 291
    edited March 2008
    The plastic 'thread' within an individual wire in the center, surrounded by the copper. This is Monster's Magentic Flux Tube...
    mmadden:
    Thanks! That ("Magnetic Flux Tube") is actually printed on the jacket (tho they couldn't seem to bother printing the guage).
    I can now attach my nanners in peace.
    "It's the little things, the little things..." - Sondheim
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • strang22
    strang22 Posts: 32
    edited March 2008
