Quick Interconnect cable opinion request
mmadden28
mmadden28 Posts: 4,283
I need to hook up my prepro to my amp (5 channels)
I also need to connect my SACD to my prepro (6 channels)
As far as I can tell this uses standard audio RCA cables for either connection.
right?
I don't have much budget left for expensive ICs, so I am trying to keep it low, especially since we're talking about a dozen cables!! I can always upgrade later
Anybody have any thoughts on the Belkin PureAV Silver audio cables?
Buy.com has them for about $20 ea.
Also, should I worry about length? I am looking at the 4', but from some sellers, the 8' is only $2 more-Just wondering if I might be asking for interference with a loinger cable. It would be nice to have the extra play.
And while I'm on the Belkin topic-Any thoughts on the PureAV Bananas and Spades?
____________________
Pool: Atrium 60's/45's
Post edited by mmadden28 on
  • Face
    Face Posts: 14,340
    edited March 2008
    I have some blue jeans cables I'm about to sell.
    http://bluejeanscable.com/store/6channel/index.htm
    Belden 1505, 3' length, 5.1(6.0) config.
    Looking for $50 plus ship. You can PM me if you're interested.
  • John K.
    John K. Posts: 822
    edited March 2008
    MM, that's right; the usual coaxial cable with an RCA plug on each end is what's needed for all the connections, and there's no need to be concerned about interference being picked up by a slightly longer cable.
    There's no good reason to pay anything near what those Belkin cables would cost, and if you'd like them a little longer than 4' , six pairs of these 6' cables would be fine for a total of about $16. Also, there'd be no need to "upgrade" them in the future, since no upgrade would be possible except in the amount of money that you'd spend. As many audio consumers have learned by dealing with MonoPrice and others which sell at reasonable prices, there's no correlation between the price paid for cables and the sound quality of their setups.
  • mmadden28
    edited March 2008
    Face wrote: »
    :cool:
    Interested-but I'm not sure 3' is long enough. Let me check.
    John K. wrote: »
    Their description is shown as 75 ohm coax cables-I thought only video cables were 75 ohms?
    but, I guess I can't go wrong for $16-
  • Ricardo
    Ricardo Posts: 10,636
    edited March 2008
    John K. wrote: »
    I hate when people say these things as if they were confirmed facts. An "IMO" here and there would be nice...because this is just that, YOUR opinion.
    SOPA
  • danger boy
    danger boy Posts: 15,722
    edited March 2008
    check this link out
    http://www.accessories4less.com/make-a-store/item/IXOSXHT503200/IXOS/XHT503-6-CHANNEL-SACD/DVD-A-AUDIO-CABLE-2M/1.html
    this is 6 RCA 2 meter (6ft) cables all bundled into one thick cable.. that would help cut down on the back of your system becoming all cluttered.
    it's the one I use. and for the price, you can't beat it really. the length is right for your application.. check it out.
    PolkFest 2012, who's going>?
    tonyb Posts: 33,067
    edited March 2008
    It always baffles me when you spend good money on some decent gear,and use rat shack cables to hook it all up.I guess some people don't see the value in it.
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited March 2008
    tonyb wrote: »
    What value? And where did anyone mention Radio Shack?
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    At first I thought you were talking about these which are $20 each and actually are silver...not just called silver.
    For cheapies I usually recommend Monster. Their basic THX line works well, for $15 you get a 4ft pair of interconnects that are of decent gauge, are well shielded, and use their gold turbine cut connectors for a solid grip. You could get 6 for $45 + tax from a local store, and could probably get them cheaper online.
  • wizzy
    wizzy Posts: 867
    edited March 2008
    How about 3 of these these 6ft Audioquest Alpha Snakes for $69 shipped
    http://www.abt.com/product/20212.html
  • Ricardo
    edited March 2008
    These are quality cables; you get a 5% discount and you can ask Frank for custom lenghts:
    http://signalcable.com/analoght.html
    SOPA
  • Face
    Face Posts: 14,340
    edited March 2008
    Ricardo wrote: »
    +1...
  • danger boy
    edited March 2008
    how about these? you get no discount, and they are expensive to boot.... but good though.
    http://www.cobaltcable.com/multi-channel-audio-bundle.htm
  • mmadden28
    edited March 2008
    I swear somethig is going on. This is now the 5th post reply in the past week or two that seems to have gone to never never land. Anyway, I can't exactly remember what I said-I have to think about it and I'll post again later...
    In summary though-Thanks for all the suggestions----
    I will try a couple cables out, and perhaps just buy a pair of some others just to try out. "I want to hear for myself."..
    When I get them and try them all, I'll post back with my opinions.
    Face, I sent you a PM-if they're still avail...
    Madden
  • vonnie123
    vonnie123 Posts: 326
    edited March 2008
    The Belkin Pure AV interconects are good quality, similar in build quality to the low-mid end Monster products. I am using them on a secondary DVD player.
  • mmadden28
    edited March 2008
    vonnie123 wrote: »
    Thanks :cool:
  • mmadden28
    edited March 2008
    Update-Well, I wrangled up some budget and decided to get a few cables and try 'em out and see if I can hear any differences for myself. I'm not about to go cheap, but I'm also not willing to spend a fortune (unless it will realy make that much difference (to me), so I'll start out reasonable and do some listening tests.
    I went with a set of the Monoprice Premiums; a set of the Cryotweaks Silvers ($109 for 7-I had to try out some silver's at this apparent budget price-also want to test them out with my XPA-5 to see if I experience a known issue with silvers); I still may get the Belkin PureAVs and some mid level Monsters-at least a pair of each to do some listening testing.
    Some of the other choices were either to expensive (for the budget-especially without any listening tests first), too bulky for my setup, or I simply had to make a decision somewhere..
    I'll post back with my observations.
    -Madden
  • jabrax
    jabrax Posts: 315
    edited March 2008
    mmadden28 wrote: »
    -Madden
    Madd - are they silver wire, or copper with silver outer? I cant find these on monoprice site.
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
  • mmadden28
    edited March 2008
    jabrax wrote: »
    Actually I was listing several cables. I see now though that could have been read differently.
    The Monoprice cables I got are here as John K linked to. (I'm still waiting on their delivery-ugh!)
    The Cryotweak Silvers I got are here at TweekGeek as Gaara linked to.
  • Hi-Buy
    Hi-Buy Posts: 110
    edited April 2008
    I am thinking about trying those cryotweaks Silvers. Seems like a good deal. Nice find !
    I wonder what gauge it is ? Anyone try these yet ? Sorry, for the thread-jack.
    Big thanks to "Neskahi" !
  • mmadden28
    edited April 2008
    Its OK to me, seems like a relavant question in this dormant thread.
    I haven't tried the Cryotweak silvers yet. However they appear to be well built with what looks like a quality RCA connector. They even shipped them with a plastic sleeve around the connectors to prevent them from getting dinged up-To me its a nice touch to show they care about quality. Of course they don't come in a fancy schmancy velvet lined gift box. Hmm, does that mean they won't have that fancy schmancy velvety sound? ;)
    I am currently using the monoprice ones I got (for both the SACD to AVR and the AVR to the amp). I got the 6 footers so I would have an easier time-I have my equipment in my entertainment center which- well is not really designed well for the equipment-I have no rear panel access, etc. So I have to pull the avr or the amp out to access the rear and doing that requires cables longer that 3'.
    The Cryotweaks are 3'. I plan to try them out on my SACD to AVR setup and compare, but not until I get the whole system tweaked to my liking and more importantly not until I get more familiar with the sound as a baseline.
    The 3 footers will just work with some maneuvering-I am just changing things a bit much right now to fuss with 3' cables.
