So, I know the question is floating around
VR3
VR3 Posts: 29,532
Will Sid really go subwooferless?
Well, the answer is semi - yes, for the moment anyways...
Im thinking about getting a VMPS dedicated subwoofer -- lay it down sideways on the bottomg shelf of my TV stand behind the preamp and CDP (since I play my sub at such low volume anyways) --
Get an amp that has a built in xover in it (compact), etc etc...
The 12" Megawoofer is a beast, so that should be an excellent adventure...
But for now, I think I will enjoy having no subs
Post edited by VR3 on
    VR3 Posts: 29,532
    edited March 2008
    Im also contemplating an ACI Force...
    Itll also work
    To bad I cant audition these subs
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    It really isn't floating around.
  • engtaz
    engtaz Posts: 7,669
    edited March 2008
    Go 18" sub or go home. LOL
    engtaz
    engtaz
  • george daniel
    george daniel Posts: 12,096
    edited March 2008
    Do you REALLY need a sub with the 7u's and the mono's?
    edited March 2008
    I think sex and drugs have put a strain on the youg lads wallet.:)
    VR3 Posts: 29,532
    edited March 2008
    I dont -really- need a sub, no...
    But a sub would definitely had some fill to movies and music with low low bass passages... but the 7u has tons of bass for the most part...
  • engtaz
    engtaz Posts: 7,669
    edited March 2008
    For movies yes. I agree. Run 2 channel in stereo (no LFE) and Movies in surround sound. GO FOR IT. LOL
    engtaz
    engtaz
    VR3 Posts: 29,532
    edited March 2008
    haha, I will agree though that subs add a good amount of ambience to music that speakers that arnt full range just cant match...
  • Early B.
    Early B. Posts: 7,900
    edited March 2008
    Ah, forget about a sub for now. You already experienced what huge freakin' badass dual subs can do in your room and you sold them. Anything less will be a disappointment.
    "God grooves with tubes."
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2008
    dorokusai wrote: »
    Exactly, no one really cares what you do or don't do sub wise Trey.
  • shack
    shack Posts: 11,154
    edited March 2008
    Who is this Sid, Trey, Vxwhatever person anyway?
    VR3 Posts: 29,532
    edited March 2008
    Mark and Russ...
    F you.
    Has anyone used the ACI Force?
    Or some subs from REL/Totem?
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2008
    I've heard quite a few Totem subs.
    What you need to do is go to the Home Entertainment Show (thats usually in NYC) and speak with the guys at Totem. That's how I met them in person and was able to talk to them - very nice bunch of guys.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
