Windows Media vs. Winamp
License2ILL
Did replays and replays of:
Lost boys "cry little sister"
Rick James "Superfreak"
Corey Hart "wear my sunglasses"
Billy Idol "Rebel yell"
Ice T "I'm your pusher"
Jay-Z "Lost one"
Pumped through my classics: Roland MA-8's
WinAmp is doing something...not leaps and bounds ahead of WMP but something......on "wear sunglasses" you can hear a lot more clearly the switching from L-speaker to R-speaker(beginning of song). Overall slightly crispier...and the EQ seems more precise.
Visualz are off though not in tune with the music.
You can run both apps together but I'd stop them before switching back and forth cuz you could crash your junk if you play over each other....they can play together but i dont know how long.
Jay-Z "Lost one"
The SL2000wc wow what a predicament!!!!!:D Order one today.......1-800-429-5423 for direct orders with anyone of the elite ee guys that frequent this forum.
Post edited by License2ILL on
I'm not so sure this should be a redirect. It sounds to me like it's a review of Winamp.
Were you using ASIO drivers?Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
Winamp has 10 times the audio codecs compared to WMP.
All I use is Winamp. Better search, track listing and playback quality.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
No what are those?The SL2000wc wow what a predicament!!!!!:D Order one today.......1-800-429-5423 for direct orders with anyone of the elite ee guys that frequent this forum. -
Winamp
engtazengtaz
New convert to winamp, and I love it. Sounds much better than WMP.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
License2ILL wrote: »No what are those?
Basically, whenever you play any music in windows, it has to go through Window's K-Mixer which down or up samples everything to 44.1, 16-bit. Even if you're playing audio which is already in that format, it will reconvert it. The end result: windows screws with the audio before it hits your sound card. ASIO drivers lets you bi-pass window's internal mixer and go strait to the sound card (assuming it supports it).
Basically, it makes it sound even better
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
foobar 2000 is good too--- lightweight and supports virtually every format. i still use winamp a lot if only because i have been doing so for better than 10 years.
http://www.foobar2000.org/
agear list:
1 down, 4 up.... -
I use foobar 2000.
I use Winamp - WMP tries to do too much checking or loading or something at startup and ocassionally freezesAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
How is winamp vs. itunes? I like itunes better than WMP, but havent used winamp in a long time.
I think They both suck.
But knock yourself out.
RT1 -
Winamp is lighter than iTunes and sounds better IMNSHO. The skin it now uses (obviously you can change it) has a a more WMP/iTunes feel about it, so it might be worth checking out for you.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
Yeah - I prefer Winamp over iTunes tooYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
