WTB remote for Carver HR-772
Fongolio
Fongolio Posts: 3,516
edited March 2008 in Wanted (WTB) Classifieds
I'm looking for the owners manual and the remote control for a Carver HR-772 receiver. Or if anyone knows of a universal that works on this unit that would be helpful as well. Thanks.
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Post edited by Fongolio on
    treitz3 Posts: 20,001
    edited March 2008
    Any Logitech should work. Carver has two learning remotes, but you have to know someone with the original remote in order for it to learn all of the functions.
  • avguytx
    avguytx Posts: 1,628
    edited March 2008
    I have a Harmony that's programmed to work my CT-17 and it does all the main stuff I need it to do. Plus, it works the Carver TL-3300 CD player even if I do have the original remote for it. Still nice to have one remote do it all.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • scootchu
    scootchu Posts: 100
    edited March 2008
    I have a couple of Carver remotes. Let me check on that tomorrow.
  • scootchu
    scootchu Posts: 100
    edited March 2008
    I have 4 Carver remotes, but one is a CD remote. I tried to find the model number for the remote you need, but didn't have any luck. Do you have the manual and if so what remote model do you need?
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited March 2008
    What model remotes do you have?
  • Grimster74
    Grimster74 Posts: 2,577
    edited March 2008
    Just checked the database for the URC Aurora remote I have for sale http://www.polkaudio.com/forums/showthread.php?t=65666 and the Carver HR-772 is in the database.:D I'm positive this remote will control any other device you may be using. Just a thought.
  • Fongolio
    edited March 2008
    I have found a service manual that lists the needed Carver remote as RH-77. I've tried a Harmony 550 that has the HR-772 in it's database but with no luck. I haven't ruled out the possibility that the remote sensor in the receiver is shot but every other function works perfectly on this receiver and it still sounds delicious. It makes my RTiA7's sound unbelievable. No sub required when using this receiver. Thankyou to all who have posted so far. I love this community
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
