I got some weird sounds here...
ryanjoachim
Well, not weird...per se
First thing I noticed is that on certain movies/shows, when there is nothing going on but dialog (no BG music) I can hear a bass tone going at regular intervals. It'll hit for a second, wait, then hit again. This happens during speech and when there's silence.
It doesn't always happen though...
Also, I've noticed that the "s" sounds in words are really harsh, almost like they are emphasized.
Are these normal, or does it sound like more of a connection/setting issue?
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
It might just be a little residue from the sins of your youth kicking loose in your veins
Happens to me all the time. DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Did you buy that 605 as a refurb?HT SYSTEM-
lsi 9's -
Nope, the 605 was a factory purchase"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
On a more serious note, are you sure you don't have a ground loop hum happening. A ground loop can be a pretty low frequency hum and intermittent. I would try a ground loop isolator on your cable or satellite feed.DKG999
What is your LFE crossover set to?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ok...idiot here.
What's a ground loop, and how to I make one?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
Crossover on the sub is 120hz (per Polk tech advice)
I thought that with a sub cable that the crossover is handled by the receiver?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
If you're using the LFE input on the subwoofer, yes, it's handled by the AVR. You're probably getting the lower end of the track, scene or dialogue, thru the subwoofer. Crank the sub Xover all the way up, Sub to YES and adjust it at the AVR to 80....work from there.
The "S" issue is called sibilance and that's got nothing to do with the other. That's inherent on the media involved and can be enhanced by a number of things.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Thanks for the help!"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
Regarding the sibilance, couple things to verify:
1) make sure you do not have an EQ enabled that is boosting the highs (turn off the EQ feature if your receiver has one)
2) make sure any treble adjustments are at "0"
Also, some programming has a lot of sibilance, and the more lively your speaker's highs, the more this will be pronounced.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
When did you buy that 605?
It has a documented issue of heat buildup in initial builds that results in random popping sounds. Onkyo has fixed this issue now. When you hear this sound and rear right corner of receiver is too hot to touch then you definitely has this issue. Onkyo will fix it for free, you just need to send this to their service center.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
After some chili and a few beers,you won't believe the weird sounds I get.HT SYSTEM-
lsi 9's -
I got my 605 in January of this year"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
As mentioned above, lower the LFE to 80hz.
Have you run the Audyssey setup?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I don't like using Audyssey because of the layout of my room.
It likes to set the sub to 0db (since I'm in an appt that's too much) I like to turn the sub up to max, and use the receiver itself to turn the bass down."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
