Quick Amp question
Mauskar
When running speaker cables from an amp to RTi10's do i need to connect the cables to all four binding posts on each speaker. Or do I just connect them to either the top two OR lower two binding posts?
Post edited by Mauskar on
If you have the jumpers in place, just connect to the lower two,IMO,otherwise you might want to consider bi-wiring them,,or better yet,, just make some jumpers out of speaker wire,,hope this helps.JC approves....he told me so. (F-1 nut)
As long as the jumpers (metal strip connecting top and bottom binding posts) are in place, you only need to connect to either the top or the bottom posts, not both.
Huh?
These are speakers that I bought from sound advice brand new, so the jumpers should be connecting the both the bottom and top binding posts, correct? -
Huh?
Just look on the speaker's binding post and see if the jumpers are there or not. I have my Studio's biwired because I was given 100ft of Audioquest speaker cables when I bought my speakers.Display: Sony XBR3 46"
Pre/Pro: Marantz AV7005
Amplifiers: Anthem MCA20 / Anthem MCA30
CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
DVD: Denon 3930CI
BD: Pioneer Elite 05FD
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Media Streamer: WDTV Live Hub
Power Console: Panamax 5300PM
Speakers: Paradigm Reference Studio v.3
Subwoofer: SVS 16-46PC+
Preamp: Parasound P3
Amplifier: BAT VK60 Tube
Sacd: Sony 777ES
Power Console: Ultralink PGX-500
Speakers: Paradigm Reference Studio 20 v.5 -
Huh?
Yes ,correctHT SYSTEM-
