Adcom GFA555 original version, pretty face
SKsolutions
For those looking to never worry about meeting Cathy's 200W minimum, here is your new amp. 200W@8 ohm, 350W@4 ohm (LSi). I bought two of these to make sure that I got a clean one, and of course both got a bit of a bump during shipping. This is the cleaner face with no real smudges or discoloration. In my cabinet, it looked perfectly clean.
The imperfections: . Two tiny pinpricks on the face, which you can make out in the pictures, and the other is a slight nick on the back edge of the front face panel. You will see the pinpricks if you look for them in bright light. You won't see the nick in the back when installed in a rack, unless you are behind it. Fedex felt obliged to manhandle this one a bit, and you can see the result on the heatsink/side cabinet. Those that are unfamiliar, there are four separate heat sinks in the rear, each held by four screws. The damaged fin one has only two screws holding it (top), and it will wiggle a bit if you force it. The rest of the case is clean.
Price: 330$ SOLD plus shipping. I will guarantee that it works as it should, and will take it back, minus shipping, within 14 days if you aren't happy. I believe I've posted the picture of the guts on this thing somewhere, and I can email it if interested. Caps look good and will keep the unit playing 30 seconds after you cut the power. Both channels take about the same time to discharge. Unit sounds perfect. Bought from original owner in Arizona who claims limited use. Checking the connections and interior, I have to agree. I've had this one around 5 months.
Shipping is from Boston and at the buyers expense. Pick up, OK.
Packing: It won't be pretty. It will be industrial strength, and boxed within a box. Takes me an hour or better. This of course is free.
Interested, post here please. Those with feedback here have priority.
Sean
Smaller pix coming.
Sean
Smaller pix coming.
-Ignorance is strength -
Post edited by SKsolutions on
Your pics are too small, care to enlarge them?:D
Things were wider than Mr.Walmart, -can't have that. Resizing for your convenience:D-Ignorance is strength -
im def interested..did you say a price?
Sean is good people. Buy with confidence!
Is the dent in the **** a putoff? Price drop.-Ignorance is strength -
whefjewhfjkhwefkjh...its mine hands off...SK pm me your paypal addy and i will get you the funds. just for the record i hate you people for making me spend more money:)
SOLDY. Adam, a return customer is always a good thing. I'll pack it up tomorrow, and use panties instead of peanuts just like you asked.
-Ignorance is strength - -
oooo baby yea just make sure you wear them to bed tonight so when they get here your smell is still fresh...
As you know, it's always panties or chaps with me.
Thanks adam, that was quick and easy as usual, and I'll bulletproof it for you.-Ignorance is strength - -
ill make sure to return the favor with the csi30
