Adcom GFA555 original version, pretty face
SKsolutions
SKsolutions Posts: 1,820
edited March 2008 in For Sale (FS) Classifieds
For those looking to never worry about meeting Cathy's 200W minimum, here is your new amp. 200W@8 ohm, 350W@4 ohm (LSi). I bought two of these to make sure that I got a clean one, and of course both got a bit of a bump during shipping. This is the cleaner face with no real smudges or discoloration. In my cabinet, it looked perfectly clean.
The imperfections: . Two tiny pinpricks on the face, which you can make out in the pictures, and the other is a slight nick on the back edge of the front face panel. You will see the pinpricks if you look for them in bright light. You won't see the nick in the back when installed in a rack, unless you are behind it. Fedex felt obliged to manhandle this one a bit, and you can see the result on the heatsink/side cabinet. Those that are unfamiliar, there are four separate heat sinks in the rear, each held by four screws. The damaged fin one has only two screws holding it (top), and it will wiggle a bit if you force it. The rest of the case is clean.
Price: 330$ SOLD plus shipping. I will guarantee that it works as it should, and will take it back, minus shipping, within 14 days if you aren't happy. I believe I've posted the picture of the guts on this thing somewhere, and I can email it if interested. Caps look good and will keep the unit playing 30 seconds after you cut the power. Both channels take about the same time to discharge. Unit sounds perfect. Bought from original owner in Arizona who claims limited use. Checking the connections and interior, I have to agree. I've had this one around 5 months.
Shipping is from Boston and at the buyers expense. Pick up, OK.
Packing: It won't be pretty. It will be industrial strength, and boxed within a box. Takes me an hour or better. This of course is free.
Interested, post here please. Those with feedback here have priority.
Sean
Smaller pix coming.
-Ignorance is strength -
Post edited by SKsolutions on
